* PCI_bus/Makefile.am: Remove all-local: $(ARCH).
* tod/Makefile.am: Remove all-local: $(ARCH).
* PCI_bus/PCI.h, clock/clock.c, console/85c30.c, console/85c30.h,
console/console.c, console/consolebsp.h,
console/consolereserveresources.c, console/tbl85c30.c, include/bsp.h,
include/coverhd.h, include/gen2.h, include/tod.h, startup/FPGA.c,
startup/bspclean.c, startup/bspstart.c, startup/genpvec.c,
startup/setvec.c, startup/vmeintr.c, timer/timer.c, tod/tod.c: URL
for license changed.
PCI_bus/Makefile.am: Reflect having moved automake.
tod/Makefile.am: Reflect having moved automake.
* PCI_bus/Makefile.am: Don't include @RTEMS_BSP@.cfg.
* tod/Makefile.am: Don't include @RTEMS_BSP@.cfg.
* vectors/Makefile.am: Don't include @RTEMS_BSP@.cfg.
* PCI_bus/Makefile.am: Use .$(OBJEXT) instead of .o.
* tod/Makefile.am: Use .$(OBJEXT) instead of .o.
* PCI_bus/PCI.h, clock/clock.c, console/85c30.c, console/console.c,
console/consolebsp.h, console/consolereserveresources.c,
console/tbl85c30.c, include/bsp.h, include/coverhd.h, include/gen1.h,
include/gen2.h, startup/82378zb.c, startup/FPGA.c,
startup/bspstart.c, startup/genpvec.c, startup/setvec.c,
startup/vmeintr.c, timer/timer.c: Fixed typo.
* PCI_bus/Makefile.am, clock/Makefile.am, console/Makefile.am,
tod/Makefile.am, vectors/Makefile.am, wrapup/Makefile.am: Include
compile.am
converted to automake.
dependencies of "Makefile".
--enable-maintainer-mode.
future.
cd <rtems-source-tree>
this week until now.
It consists of 3 parts:
1. a patch
2. a perl script (acpolish)
plural).
configure scripts etc.
added by acpolish.
To apply this:
./rtems-polish.sh
Later:
cvs add contrib
cvs add contrib/acpolish
cvs commit
