* | 2007-04-12 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2007-04-12 | 1 | -4/+2 |
| | | | | * bsp_specs: Remove qrtems_debug. | ||||
* | 2003-09-19 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2003-09-19 | 1 | -8/+0 |
| | | | | * bsp_specs: Remove *lib:. | ||||
* | 2003-08-06 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2003-08-06 | 1 | -3/+0 |
| | | | | | * bsp_specs: Remove -D__embedded__ -Asystem(embedded) from cpp. Remove cpp, old_cpp (now unused). | ||||
* | 2002-08-21 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2002-08-21 | 1 | -4/+4 |
| | | | | * bsp_specs: Added support for -nostdlibs. | ||||
* | 2001-12-22 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Joel Sherrill | 2002-01-04 | 1 | -1/+1 |
| | | | | | * bsp_specs: Replace -lrtemsall with -lrtemsbsp -lrtemscpu, replace -lrtemsall_g with -lrtemsbsp_g -lrtemscpu_g. | ||||
* | Merged from 4.5.0-beta3a | Joel Sherrill | 2000-06-12 | 1 | -1/+1 |
* | Typo -- removed blank line at top of file. | Joel Sherrill | 1999-08-06 | 1 | -1/+0 |
* | Patch from Andrew Bray <andy@chaos.org.uk>: | Joel Sherrill | 1999-04-06 | 1 | -1/+4 |
| | | | | | | In your various bsp_specs files, even when ecrti.o is defined as a startfile, ecrtn.o is not defined as an endfile. Instead it seems to be in the library list - untidy. | ||||
* | Enhanced to support -qrtems_debug. | Joel Sherrill | 1999-02-19 | 1 | -3/+9 |
* | BSP for Vista Score603e added. | Joel Sherrill | 1999-02-19 | 1 | -0/+18 |
