* Makefile.am: Fix typo in previous patch.
* Makefile.am: Merge-in wrapup/Makefile.am.
* wrapup/Makefile.am: Remove.
* vectors/vectors.S: Remove XCOFF support.
* startup/linkcmds: Add .gnu.linkonce.b.* section.
* startup/linkcmds: Now links.
* Makefile.am: Use ../../shared/tod.h instead of include/tod.h.
* include/tod.h: Remove.
* Makefile.am: Eliminate CFLAGS_OPTIMIZE_V.
* startup/linkcmds: Remove warnings.
* Makefile.am, wrapup/Makefile.am: Remove build-variant support.
PR 610/bsps
* Makefile.am: Add include/tm27.h, Cosmetics.
* include/tm27.h: Final cosmetics.
* include/tm27.h: New.
PR 613/bsps
PR 614/bsps
* vectors/vectors.S: Include <rtems/asm.h> instead of <asm.h>.
* startup/genpvec.c: Include <rtems/chain.h> instead of <chain.h>.
* console/consolebsp.h: Include <rtems/ringbuf.h> instead of <ringbuf.h>.
* startup/vmeintr.c: Include <rtems/vmeintr.h> instead of <vmeintr.h>.
* PCI_bus/PCI.c, PCI_bus/PCI.h, PCI_bus/flash.c, PCI_bus/universe.c,
clock/clock.c, console/85c30.c, console/console.c,
console/consolebsp.h, include/bsp.h, include/gen2.h, startup/FPGA.c,
startup/Hwr_init.c, startup/bspstart.c, startup/genpvec.c,
startup/spurious.c, startup/vmeintr.c, timer/timer.c, tod/tod.c:
Convert to using c99 fixed size types.
* Makefile.am: Reflect changes to bsp.am.
Preinstall dist_project_lib*.
* Makefile.am: Use CPPASCOMPILE instead of CCASCOMPILE.
* wrapup/Makefile.am: Convert to automake-building rules.
PCI_bus/Makefile.am, startup/Makefile.am, timer/Makefile.am,
tod/Makefile.am, vectors/Makefile.am. Use automake compilation rules.
* clock/Makefile.am, console/Makefile.am, PCI_bus/Makefile.am,
startup/Makefile.am, timer/Makefile.am, tod/Makefile.am,
vectors/Makefile.am: Remove.
* Makefile.am: Merge-in start/Makefile.am.
* start/Makefile.am: Remove.
* configure.ac: Add nostdinc to AUTOMAKE_OPTIONS.
Add RTEMS_PROG_CCAS.
* wrapup/Makefile.am: Reflect changes to libcpu.
* start/Makefile.am: Ditto.
* startup/Makefile.am: Ditto.
* wrapup/Makefile.am: Eliminate $(LIB).
Use noinst_DATA to trigger building libbsp.a.
* PCI_bus/Makefile.am: Eliminate VPATH.
* clock/Makefile.am: Eliminate VPATH.
* console/Makefile.am: Eliminate VPATH.
* start/Makefile.am: Eliminate VPATH.
* startup/Makefile.am: Eliminate VPATH.
* timer/Makefile.am: Eliminate VPATH.
* tod/Makefile.am: Eliminate VPATH.
* vectors/Makefile.am: Eliminate VPATH.
* PCI_bus/Makefile.am: Cosmetics.
* tod/Makefile.am: Cosmetics.
* vectors/Makefile.am: Cosmetics.
* PCI_bus/Makefile.am: Remove all-local: $(ARCH).
* tod/Makefile.am: Remove all-local: $(ARCH).
* bsp_specs: Remove *lib:.
* PCI_bus/PCI.h, clock/clock.c, console/85c30.c, console/85c30.h,
console/console.c, console/consolebsp.h,
console/consolereserveresources.c, console/tbl85c30.c, include/bsp.h,
include/coverhd.h, include/gen2.h, include/tod.h, startup/FPGA.c,
startup/bspclean.c, startup/bspstart.c, startup/genpvec.c,
startup/setvec.c, startup/vmeintr.c, timer/timer.c, tod/tod.c: URL
for license changed.
* PCI_bus/PCI.c, PCI_bus/flash.c, PCI_bus/universe.c: Removed incorrect
statement about copyright assignment.
PCI_bus/Makefile.am: Reflect having moved automake.
tod/Makefile.am: Reflect having moved automake.
* startup/linkcmds*: Add FreeBSD sysctl() sections.
* PCI_bus/Makefile.am: Don't include @RTEMS_BSP@.cfg.
* tod/Makefile.am: Don't include @RTEMS_BSP@.cfg.
* vectors/Makefile.am: Don't include @RTEMS_BSP@.cfg.
