* | Change all references of rtems.com to rtems.org. | Chris Johns | 2014-03-21 | 3 | -3/+3 |
* | termios: Update due to API changes | Sebastian Huber | 2013-06-25 | 1 | -21/+23 |
| | | | | | Termios notifies now the driver about an inactive transmit with the length argument set to zero. | ||||
* | bsp/qoriq: Avoid NULL pointer access | Sebastian Huber | 2013-05-27 | 1 | -5/+11 |
* | libchip/serial: Add const qualifier | Sebastian Huber | 2013-02-11 | 2 | -2/+2 |
* | Remove All CVS Id Strings Possible Using a Script | Joel Sherrill | 2012-05-11 | 3 | -6/+0 |
* | 2011-10-18 Jennifer Averett <Jennifer.Averett@OARcorp.com> | Jennifer Averett | 2011-10-18 | 3 | -13/+9 |
| | | | | | | | PR 1917/bsps * Makefile.am, console/console-config.c, console/uart-bridge-master.c, console/uart-bridge-slave.c, startup/bspstart.c: Modifications to add dynamic tables for libchip serial drivers. | ||||
* | 2011-07-21 Sebastian Huber <sebastian.huber@embedded-brains.de> | Sebastian Huber | 2011-07-21 | 3 | -0/+616 |
PR 1799/bsps * .cvsignore, ChangeLog, Makefile.am, README, bsp_specs, configure.ac, clock/clock-config.c, console/console-config.c, console/uart-bridge-master.c, console/uart-bridge-slave.c, include/.cvsignore, include/bsp.h, include/hwreg_vals.h, include/intercom.h, include/irq.h, include/mmu.h, include/qoriq.h, include/tm27.h, include/tsec-config.h, include/u-boot-config.h, include/uart-bridge.h, irq/irq.c, make/custom/qoriq.inc, make/custom/qoriq_core_0.cfg, make/custom/qoriq_core_1.cfg, make/custom/qoriq_p1020rdb.cfg, network/if_intercom.c, network/network.c, rtc/rtc-config.c, shmsupp/intercom-mpci.c, shmsupp/intercom.c, shmsupp/lock.S, start/start.S, startup/bsppredriverhook.c, startup/bspreset.c, startup/bspstart.c, startup/linkcmds.base, startup/linkcmds.qoriq_core_0, startup/linkcmds.qoriq_core_1, startup/linkcmds.qoriq_p1020rdb, startup/mmu-config.c, startup/mmu-tlb1.S, startup/mmu.c: New files. |
