BSP_PRESS_KEY_FOR_RESET=0
BSP_RESET_BOARD_AT_EXIT=1
BSP_PRINT_EXCEPTION_CONTEXT=1
BSPs can use the bsp_fatal_extension() to provide BSP-specific fatal
error handling. There is no need for a _BSP_Fatal_error().
Close #3246.
Due to a new rtems_panic() implementation, it is possible to replace the
PowerPC-specific BSP_panic() with rtems_panic(). Remove BSP_panic()
implementations.
Close #3245.
Update #3239.
Change bsp_interrupt_vector_enable() and bsp_interrupt_vector_disable()
to not return a status code. Add bsp_interrupt_assert() and use it to
validate the vector number in the vector enable/disable implementations.
warnings
updates #2564.
Update #2408.
The size of the sample executables without this option were:
119012 8704 15168 142884 22e24 base_sp.exe
128516 7612 15104 151232 24ec0 hello.exe
54276 4544 11584 70404 11304 minimum.exe
565444 80124 27456 673024 a4500 fileio.exe
142116 10432 15296 167844 28fa4 nsecs.exe
174276 21308 15808 211392 339c0 paranoia.exe
122180 8896 15200 146276 23b64 ticker.exe
121540 8800 18944 149284 24724 unlimited.exe
1010276 68228 22808 1101312 10ce00 cxx_iostream.exe
228580 20112 15856 264548 40964 cdtest.exe
217348 22620 16992 256960 3ebc0 capture.exe
The size of the sample executables with this option enabled were:
104356 7168 15168 126692 1eee4 base_sp.exe
111780 6080 15072 132932 20744 hello.exe
40836 3008 11584 55428 d884 minimum.exe
540900 76640 27168 644708 9d664 fileio.exe
128228 8896 15264 152388 25344 nsecs.exe
159044 19744 15776 194564 2f804 paranoia.exe
107812 7328 15200 130340 1fd24 ticker.exe
105380 7296 18912 131588 20204 unlimited.exe
199644 15296 15528 230468 38444 cxx_iostream.exe
206772 16800 15376 238948 3a564 cdtest.exe
200228 20864 16992 238084 3a204 capture.exe
Update #2408.
Fix broken RTEMS linker set descriptions introduced by
b618d8cfc54f84d4ed03dc7b7fa510c872e6128a.
Update #2408.
do
echo $b
# echo $g
-i $b
done
The file console-polled.h provides the prototypes for the three
required methods when implementing a single port polled console
driver. This paradigm is common on simulators and simple hardware.
+ Updated the BSPs Makefile.am to make console-polled.h available.
+ Regenerated the BSPs preinstall.sm.
+ Updated console support files to include <bsp/console-polled.h>.
+ Updated console support files to make printk() support method static.
not updated.
The TLS section symbols had wrong values in case of an empty TLS data
section and a nonempty TLS BSS section.
Instead of SPRG0 (= special purpose register 272) use the new global
symbol _PPC_INTERRUPT_DISABLE_MASK to store the interrupt disable mask.
The benefit is that it is now possible to disable interrupts without
further run-time initialization in boot_card().
At least on Freescale e500 cores this leads also to a faster execution
since the mfmsr and mfspr instruction require four cycles to complete.
The instructions to load the mask value can execute while the mfmsr is
in progress.
Conflicts:
for details.
The clock driver used previously the bsp_clicks_per_usec value. For a
33333333Hz time base frequency this leads to a relative error of one per
cent for example due to integer truncation.
* start/start.S: Align stack and tag TOS with a NULL
pointer (help terminate when walking the stack).
