for details.
The clock driver used previously the bsp_clicks_per_usec value. For a
33333333Hz time base frequency this leads to a relative error of one per
cent for example due to integer truncation.
* start/start.S: Align stack and tag TOS with a NULL
pointer (help terminate when walking the stack).
* Makefile.am: Remove references to non-existing files.
* startup/bspstart.c:
* beatnik/include/bsp.h, beatnik/irq/irq.h, beatnik/pci/gt_pci_init.c,
ep1a/console/polled_io.c, ep1a/irq/openpic_xxx_irq.c,
gen5200/include/irq.h, gen5200/irq/irq.c, gen5200/startup/bspstart.c,
haleakala/irq/irq.c, mbx8xx/irq/irq.c, mbx8xx/irq/irq.h,
motorola_powerpc/include/bsp.h, mpc8260ads/irq/irq.c,
mpc8260ads/irq/irq.h, mvme3100/include/bsp.h, mvme3100/irq/irq.h,
mvme3100/start/start.S, mvme5500/include/bsp.h, mvme5500/irq/irq.h,
psim/include/bsp.h, psim/include/coverhd.h, psim/irq/irq.h,
psim/shmsupp/addrconv.c, psim/shmsupp/getcfg.c,
psim/startup/linkcmds, psim/tools/psim-gdb-top.in,
psim/tools/psim-top.in, psim/tools/runtest-top.in, qemuppc/irq/irq.h,
score603e/irq/irq.c, shared/bootloader/bootldr.h,
shared/bootloader/em86.c, shared/bootloader/em86real.S,
shared/bootloader/exception.S, shared/bootloader/head.S,
shared/bootloader/lib.c, shared/bootloader/misc.c,
shared/bootloader/mm.c, shared/bootloader/pci.c,
shared/console/console.c, shared/console/consoleIo.h,
shared/console/inch.c, shared/console/keyboard.h,
shared/console/polled_io.c, shared/irq/i8259.c, shared/irq/irq.h,
shared/irq/openpic_i8259_irq.c, shared/motorola/motorola.c,
shared/motorola/motorola.h, shared/openpic/openpic.c,
shared/openpic/openpic.h, shared/pci/pci.c,
shared/residual/residual.c, shared/start/start.S, ss555/irq/irq.h:
Fix typo where license said found in found in.
* configure.ac: Remove AC_CHECK_SIZEOF([void *]).
* configure.ac: Added AC_CHECK_SIZEOF macro.
* include/irq-config.h: Removed file.
* Makefile.am, preinstall.am: Reflect change above.
* include/irq.h: Moved defines from 'include/irq-config.h'.
* make/custom/qemuppc.cfg: Remove RTEMS_BSP_FAMILY.
* make/custom/qemuppc.cfg: New (relocated from /make/custom).
* Makefile.am: Remove reference to timer_SOURCES.
* include/bsp.h: BSP has plenty of memory.
* startup/cmain.c: Comment out prints.
add basic IRQ support (for decrementer)
* start/start.S, startup/cmain.c, startup/linkcmds: add support
for sdata* sections
* startup/bsppanic.c: some cleanup
* include/bsp.h: BSP does not have much memory. Limited to BIOS space.
* irq/irq.h: New file.
* .cvsignore, ChangeLog, Makefile.am, README, bsp_specs, configure.ac,
preinstall.am, console/console-io.c, include/.cvsignore,
include/bsp.h, start/start.S, startup/bsppanic.c, startup/cmain.c,
startup/linkcmds: New files.
