* | 2010-06-29 Joel Sherrill <joel.sherrill@oarcorp.com> | Joel Sherrill | 2010-06-29 | 2 | -4/+4 |
| | | | | * configure.ac: Remove AC_CHECK_SIZEOF([void *]). | ||||
* | 2010-06-29 Joel Sherrill <Joel.Sherrill@OARcorp.com> | Jennifer Averett | 2010-06-29 | 2 | -0/+8 |
| | | | | * configure.ac: Added AC_CHECK_SIZEOF macro. | ||||
* | 2010-04-30 Sebastian Huber <sebastian.huber@embedded-brains.de> | Sebastian Huber | 2010-04-30 | 5 | -84/+11 |
| | | | | | | * include/irq-config.h: Removed file. * Makefile.am, preinstall.am: Reflect change above. * include/irq.h: Moved defines from 'include/irq-config.h'. | ||||
* | Whitespace removal. | Ralf Corsepius | 2009-11-30 | 3 | -3/+3 |
* | Whitespace removal. | Ralf Corsepius | 2009-11-28 | 1 | -1/+1 |
* | add cache.rel to Makefile | Thomas Doerfler | 2009-10-30 | 2 | -0/+5 |
* | Update for exception support changes. | Thomas Doerfler | 2009-10-23 | 5 | -42/+28 |
* | 2009-10-21 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2009-10-21 | 2 | -3/+4 |
| | | | | * make/custom/qemuppc.cfg: Remove RTEMS_BSP_FAMILY. | ||||
* | 2009-10-20 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2009-10-20 | 2 | -1/+5 |
| | | | | * configure.ac: Don't add -ansi -fasm to CFLAGS. | ||||
* | 2009-10-15 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2009-10-15 | 2 | -0/+29 |
| | | | | * make/custom/qemuppc.cfg: New (relocated from /make/custom). | ||||
* | 2009-10-14 Joel Sherrill <joel.sherrill@oarcorp.com> | Joel Sherrill | 2009-10-14 | 2 | -1/+5 |
| | | | | * Makefile.am: Remove reference to timer_SOURCES. | ||||
* | 2009-10-12 Joel Sherrill <joel.sherrill@OARcorp.com> | Joel Sherrill | 2009-10-12 | 3 | -4/+10 |
| | | | | | * include/bsp.h: BSP has plenty of memory. * startup/cmain.c: Comment out prints. | ||||
* | increase size of ROM to 4 Meg | Thomas Doerfler | 2009-10-12 | 2 | -1/+5 |
* | various changes | Thomas Doerfler | 2009-10-06 | 7 | -24/+52 |
* | add missing file | Thomas Doerfler | 2009-10-03 | 2 | -0/+138 |
* | * Makefile.am, irq/irq_config.h, irq/irq_init.c, irq/irq.h: | Thomas Doerfler | 2009-10-02 | 10 | -20/+251 |
| | | | | | | | | | add basic IRQ support (for decrementer) * start/start.S, startup/cmain.c, startup/linkcmds: add support for sdata* sections * startup/bsppanic.c: some cleanup | ||||
* | 2009-09-30 Joel Sherrill <joel.sherrill@oarcorp.com> | Joel Sherrill | 2009-10-01 | 2 | -0/+6 |
| | | | | * include/bsp.h: BSP does not have much memory. Limited to BIOS space. | ||||
* | 2009-09-24 Joel Sherrill <joel.sherrill@oarcorp.com> | Joel Sherrill | 2009-09-24 | 2 | -0/+77 |
| | | | | * irq/irq.h: New file. | ||||
* | 2009-09-24 Joel Sherrill <joel.sherrill@oarcorp.com> | Joel Sherrill | 2009-09-24 | 14 | -0/+594 |
* .cvsignore, ChangeLog, Makefile.am, README, bsp_specs, configure.ac, preinstall.am, console/console-io.c, include/.cvsignore, include/bsp.h, start/start.S, startup/bsppanic.c, startup/cmain.c, startup/linkcmds: New files. |
