PR 610/bsps
* Makefile.am: Add include/tm27.h, Cosmetics.
* include/tm27.h: Final cosmetics.
* include/tm27.h: New.
PR 613/bsps
PR 614/bsps
* vectors/align_h.S: Include <rtems/asm.h> instead of <asm.h>.
* include/bsp.h, shmsupp/getcfg.c, startup/bspstart.c,
timer/timer.c: Convert to using c99 fixed size types.
* Makefile.am: Reflect changes to bsp.am.
Preinstall dist_project_lib*.
* Makefile.am: Cosmetics.
* Makefile.am: Add $(TMPINSTALL_FILES) to all-local.
* wrapup/Makefile.am: Convert to automake-building rules.
shmsupp/Makefile.am, startup/Makefile.am, timer/Makefile.am,
vectors/Makefile.am. Use automake compilation rules.
startup/Makefile.am, timer/Makefile.am, vectors/Makefile.am: Remove.
* Makefile.am: Merge-in start/Makefile.am.
* start/Makefile.am: Remove.
* wrapup/Makefile.am: Reflect changes to
../support/*exception_processing/*.
* configure.ac: Add nostdinc to AUTOMAKE_OPTIONS.
Add RTEMS_PROG_CCAS.
* start/Makefile.am: Ditto.
* startup/Makefile.am: Ditto.
* wrapup/Makefile.am: Eliminate $(LIB).
Use noinst_DATA to trigger building libbsp.a.
* console/Makefile.am: Eliminate *.rel.
Use $(top_srcdir)/../../shared instead of ../../../shared.
* clock/Makefile.am: Eliminate VPATH.
* console/Makefile.am: Eliminate VPATH.
* shmsupp/Makefile.am: Eliminate VPATH.
* startup/Makefile.am: Eliminate VPATH.
* timer/Makefile.am: Eliminate VPATH.
* vectors/Makefile.am: Eliminate VPATH.
* wrapup/Makefile.am: Remove GENERIC_FILES.
* startup/linkcmds: Remove SEARCH_DIR.
* Makefile.am: Reworked.
* startup/linkcmds: Preparations for gcc-3.3.x.
* Makefile.am: Misc cleanups and fixes.
* shmsupp/Makefile.am: Cosmetics.
* vectors/Makefile.am: Cosmetics.
* shmsupp/Makefile.am: Remove all-local: $(ARCH).
* bsp_specs: Remove *lib:.
* console/console-io.c, include/bsp.h, include/coverhd.h,
shmsupp/addrconv.c, shmsupp/getcfg.c, shmsupp/lock.c,
shmsupp/mpisr.c, startup/bspclean.c, startup/bspstart.c,
startup/linkcmds, startup/setvec.c, tools/psim, tools/runtest,
vectors/vectors.S: URL for license changed.
* startup/bspstart.c: Removed incorrect statement about copyright
assignment.
shmsupp/Makefile.am: Reflect having moved automake.
PR 369/filesystem
* runtest: Add sample application to show the use of the
DOSFS functions
