* | Patch from Jay Kulpinski <jskulpin@eng01.gdds.com> to get cdtest.exe to run. | Joel Sherrill | 1998-12-17 | 1 | -0/+2 |
* | Patch from Ralf Corsepius <corsepiu@faw.uni-ulm.de> to rename all | Joel Sherrill | 1998-12-14 | 13 | -24/+24 |
| | | | | | .s files to .S in conformance with GNU conventions. This is a minor step along the way to supporting automake. | ||||
* | Increased default amount of RAM. | Joel Sherrill | 1998-12-03 | 1 | -1/+1 |
* | Upped the memory to 8 Mbytes. | Joel Sherrill | 1998-11-23 | 1 | -1/+2 |
* | Patch from Eric Norum <eric@skatter.usask.ca>: | Joel Sherrill | 1998-11-19 | 2 | -4/+6 |
| | | | | | | | | | | | | | | | 1) Socket timeout field changed from `short' to `long'. This makes longer timeouts possible. With a 1 kHz system clock the old system allowed timeouts only up to a little over 30 seconds! This change is a slightly cleaned-up version of the patch proposed by Ian Lance Taylor. 2) Major changes to BOOTP/DHCP reply handling. Now supports much of RFC2132. These changes were done at the request of, and with the assistance of, Erik Ivanenko. If you're making changes, you might want to change the network supplement Essentially just do a global search and replace of BOOTP with BOOTP/DHCP. | ||||
* | Commented out line which ran psim tests twice. | Joel Sherrill | 1998-10-05 | 1 | -1/+1 |
* | Changed based on patch from pc386 linkcmds from Ian Lance Taylor | Joel Sherrill | 1998-09-30 | 1 | -1/+1 |
| | | | | | | | | | <ian@airs.com>: The pc386 linker scripts omits .gnu.linkonce.r* sections. It's not a big deal, but they should be treated like .rodata sections. ELF versions of g++ generate them for static constants defined in template classes, such as string::npos. | ||||
* | Changed prototype for console_write_support to eliminate a warning. | Joel Sherrill | 1998-06-29 | 1 | -1/+5 |
* | Removed PPC_Get_timebase_register() as this is now provided by the PowerPC | Joel Sherrill | 1998-06-03 | 1 | -19/+0 |
| | | | | port itself. | ||||
* | Cleaned up to remove warnings. | Joel Sherrill | 1998-05-11 | 1 | -2/+1 |
* | Switched to termios callback structure. | Joel Sherrill | 1998-05-04 | 1 | -12/+23 |
* | Corrected and added sections to link cleanly under powerpc-rtems (ELF). | Joel Sherrill | 1998-05-04 | 1 | -1/+1 |
* | Removed tripling of workspace API when POSIX API is enabled. confdefs.h | Joel Sherrill | 1998-04-30 | 1 | -1/+3 |
| | | | | | | is now correct enough where this is not necessary. This was in to cover up the deficiencies in figuring out how much memory a GNAT/RTEMS application required. There is a good stab at this now. | ||||
* | Added wildcard to switch for monitor and termios. | Joel Sherrill | 1998-04-30 | 1 | -1/+1 |
* | Added sections and redirected some to RAM to avoid warnings. | Joel Sherrill | 1998-04-30 | 1 | -40/+47 |
* | psim now runs in both debug and non-debug mode. | Joel Sherrill | 1998-04-18 | 4 | -9/+17 |
* | Numerous changes which in total greatly reduced the amount of source | Joel Sherrill | 1998-04-15 | 2 | -34/+4 |
| | | | | | | | | | | | | code in each BSP's bspstart.c. These changes were: + confdefs.h now knows libio's semaphore requirements + shared/main.c now copies Configuration to BSP_Configuration + shared/main.c fills in the Cpu_table with default values This removed the need for rtems_libio_config() and the constant BSP_LIBIO_MAX_FDS in every BSP. Plus now the maximum number of open files can now be set on the gcc command line. | ||||
* | Transitioned to shared bsp_libc_init() and cleaned up comments. | Joel Sherrill | 1998-04-15 | 14 | -90/+96 |
* | Per suggestion from Eric Norum, went from one initial extension set | Joel Sherrill | 1998-04-15 | 1 | -14/+0 |
| | | | | | | to multiple. This lets the stack check extension be installed at system initialization time and avoids the BSP having to even know about its existence. | ||||
* | Stack checker extension now accounted for in confdefs.h | Joel Sherrill | 1998-04-14 | 2 | -7/+1 |
* | Now accounts for region used by RTEMS malloc and extension used | Joel Sherrill | 1998-04-14 | 1 | -14/+0 |
| | | | | by newlib. | ||||
* | Moved bspclean from assembly to C and made exit act properly. | Joel Sherrill | 1998-04-14 | 2 | -2/+19 |
* | new file | Joel Sherrill | 1998-04-14 | 3 | -6/+54 |
* | removed shmsupp | Joel Sherrill | 1998-04-14 | 1 | -1/+1 |
* | new files | Joel Sherrill | 1998-04-14 | 35 | -0/+3397 |
