There must be an isync after the mtmsr to ensure that the AltiVec is
enabled for subsequent instructions.
Close #2760.
do
echo $b
# echo $g
-i $b
done
The file console-polled.h provides the prototypes for the three
required methods when implementing a single port polled console
driver. This paradigm is common on simulators and simple hardware.
+ Updated the BSPs Makefile.am to make console-polled.h available.
+ Regenerated the BSPs preinstall.sm.
+ Updated console support files to include <bsp/console-polled.h>.
+ Updated console support files to make printk() support method static.
not updated.
Instead of SPRG0 (= special purpose register 272) use the new global
symbol _PPC_INTERRUPT_DISABLE_MASK to store the interrupt disable mask.
The benefit is that it is now possible to disable interrupts without
further run-time initialization in boot_card().
At least on Freescale e500 cores this leads also to a faster execution
since the mfmsr and mfspr instruction require four cycles to complete.
The instructions to load the mask value can execute while the mfmsr is
in progress.
It declares a symbol defined in the linker command file.
This avoids a linker assertion failure in the GCC test suite.
Delete ppc_exc_vector_base. Add and use
ppc_exc_initialize_with_vector_base().
Several GCC tests faild due to the outdated previous linker command
file.
Add CPU port type CPU_Exception_frame and function
_CPU_Exception_frame_print().
The CPU ports of avr, bfin, h8300, lm32, m32c, m32r, m68k, nios2, sh,
sparc64, and v850 use an empty default implementation of
Add rtems_exception_frame and rtems_exception_frame_print().
Add RTEMS_FATAL_SOURCE_EXCEPTION for CPU exceptions. Use rtems_fatal()
with source RTEMS_FATAL_SOURCE_EXCEPTION in CPU ports of i386, powerpc,
and sparc for unexpected exceptions.
Add third parameter to RTEMS_BSP_CLEANUP_OPTIONS() which controls the
BSP_PRINT_EXCEPTION_CONTEXT define used in the default
bsp_fatal_extension().
Add test sptests/spfatal26.
Add reserved system events RTEMS_EVENT_SYSTEM_NETWORK_SBWAIT and
RTEMS_EVENT_SYSTEM_NETWORK_SOSLEEP.
Add and use rtems_bsdnet_event_send().
Conflicts:
for details.
Add IRQ support components needed by new BSD code.
c/src/lib/libbsp/powerpc/psim/startup/linkcmds
* start/start.S: Add bsp_reset() label to exit point.
* Makefile.am, configure.ac: runtest for this BSP obsoleted by
rtems-testing/sim-scripts support. Please use those scripts.
* tools/.cvsignore, tools/ChangeLog, tools/Makefile.am,
tools/configure.ac, tools/psim-bottom, tools/psim-gdb-bottom,
tools/psim-gdb-top.in, tools/psim-shared, tools/psim-top.in,
tools/runtest-bottom, tools/runtest-top.in: Removed.
PR1797/bsps: Applied cleaned-up version of Kate's patch.
CONFIGURE_MALLOC_BSP_SUPPORTS_SBRK is now a 'bspopts.h'
setting and as such configurable.
* configure.ac: Remove RTEMS_CANONICAL_TARGET_CPU.
* include/bsp.h, include/tm27.h, startup/bspstart.c:
* beatnik/include/bsp.h, beatnik/irq/irq.h, beatnik/pci/gt_pci_init.c,
ep1a/console/polled_io.c, ep1a/irq/openpic_xxx_irq.c,
gen5200/include/irq.h, gen5200/irq/irq.c, gen5200/startup/bspstart.c,
haleakala/irq/irq.c, mbx8xx/irq/irq.c, mbx8xx/irq/irq.h,
motorola_powerpc/include/bsp.h, mpc8260ads/irq/irq.c,
mpc8260ads/irq/irq.h, mvme3100/include/bsp.h, mvme3100/irq/irq.h,
mvme3100/start/start.S, mvme5500/include/bsp.h, mvme5500/irq/irq.h,
psim/include/bsp.h, psim/include/coverhd.h, psim/irq/irq.h,
psim/shmsupp/addrconv.c, psim/shmsupp/getcfg.c,
psim/startup/linkcmds, psim/tools/psim-gdb-top.in,
psim/tools/psim-top.in, psim/tools/runtest-top.in, qemuppc/irq/irq.h,
score603e/irq/irq.c, shared/bootloader/bootldr.h,
shared/bootloader/em86.c, shared/bootloader/em86real.S,
shared/bootloader/exception.S, shared/bootloader/head.S,
shared/bootloader/lib.c, shared/bootloader/misc.c,
shared/bootloader/mm.c, shared/bootloader/pci.c,
shared/console/console.c, shared/console/consoleIo.h,
shared/console/inch.c, shared/console/keyboard.h,
shared/console/polled_io.c, shared/irq/i8259.c, shared/irq/irq.h,
shared/irq/openpic_i8259_irq.c, shared/motorola/motorola.c,
shared/motorola/motorola.h, shared/openpic/openpic.c,
shared/openpic/openpic.h, shared/pci/pci.c,
shared/residual/residual.c, shared/start/start.S, ss555/irq/irq.h:
Fix typo where license said found in found in.
* network/if_sim.c: Do not use printf() except for printing statistics.
* console/consupp.S, irq/irq.h, irq/irq_init.c: Add CVS Id string.
* configure.ac: Remove AC_CHECK_SIZEOF([void *]).
