1998-06-29 | Changed prototype for console_write_support to eliminate a warning. | Joel Sherrill | 1 | -1/+5 | |
1998-06-03 | Removed PPC_Get_timebase_register() as this is now provided by the PowerPC | Joel Sherrill | 1 | -19/+0 | |
port itself. | |||||
1998-05-11 | Cleaned up to remove warnings. | Joel Sherrill | 1 | -2/+1 | |
1998-05-04 | Switched to termios callback structure. | Joel Sherrill | 1 | -12/+23 | |
1998-05-04 | Corrected and added sections to link cleanly under powerpc-rtems (ELF). | Joel Sherrill | 1 | -1/+1 | |
1998-04-30 | Removed tripling of workspace API when POSIX API is enabled. confdefs.h | Joel Sherrill | 1 | -1/+3 | |
is now correct enough where this is not necessary. This was in to cover up the deficiencies in figuring out how much memory a GNAT/RTEMS application required. There is a good stab at this now. | |||||
1998-04-30 | Added wildcard to switch for monitor and termios. | Joel Sherrill | 1 | -1/+1 | |
1998-04-30 | Added sections and redirected some to RAM to avoid warnings. | Joel Sherrill | 1 | -40/+47 | |
1998-04-18 | psim now runs in both debug and non-debug mode. | Joel Sherrill | 4 | -9/+17 | |
1998-04-15 | Numerous changes which in total greatly reduced the amount of source | Joel Sherrill | 2 | -34/+4 | |
code in each BSP's bspstart.c. These changes were: + confdefs.h now knows libio's semaphore requirements + shared/main.c now copies Configuration to BSP_Configuration + shared/main.c fills in the Cpu_table with default values This removed the need for rtems_libio_config() and the constant BSP_LIBIO_MAX_FDS in every BSP. Plus now the maximum number of open files can now be set on the gcc command line. | |||||
1998-04-15 | Transitioned to shared bsp_libc_init() and cleaned up comments. | Joel Sherrill | 14 | -90/+96 | |
1998-04-15 | Per suggestion from Eric Norum, went from one initial extension set | Joel Sherrill | 1 | -14/+0 | |
to multiple. This lets the stack check extension be installed at system initialization time and avoids the BSP having to even know about its existence. | |||||
1998-04-14 | Stack checker extension now accounted for in confdefs.h | Joel Sherrill | 2 | -7/+1 | |
1998-04-14 | Now accounts for region used by RTEMS malloc and extension used | Joel Sherrill | 1 | -14/+0 | |
by newlib. | |||||
1998-04-14 | Moved bspclean from assembly to C and made exit act properly. | Joel Sherrill | 2 | -2/+19 | |
1998-04-14 | new file | Joel Sherrill | 3 | -6/+54 | |
1998-04-14 | removed shmsupp | Joel Sherrill | 1 | -1/+1 | |
1998-04-14 | new files | Joel Sherrill | 35 | -0/+3397 | |
