* shmsupp/Makefile.am: Use .$(OBJEXT) instead of .o.
* Makefile.am: Add @exceptions@ to SUBDIRS.
* configure.ac: Apply RTEMS_BSPOPTS_*(*) to merge-in settings from
make/custom/psim.cfg;
Remove RTEMS_OUTPUT_BUILD_SUBDIRS;
Add RTEMS_PPC_EXCEPTIONS([old]).
* include/Makefile.am: include force-preinstall.am.
* wrapup/Makefile.am: Apply @exceptions@.
* wrapup/Makefile: Use GENERIC_FILES = to make automake-1.5 happy.
vectors/Makefile.am, wrapup/Makefile.am: Include compile.am
from score/cpu to libcpu because the determination of which to use is
based on RTEMS_CPU_MODEL. Thus it can not be determined based solely on
multilib information.
converted to automake.
CHANGES
autoconf check
autoconf check
$(prefix)/<bsp>/make/bsp.cfg
compatible.
Makefile.ins
dependencies of "Makefile".
--enable-maintainer-mode.
future.
cd <rtems-source-tree>
all bsp_specs.
this week until now.
It consists of 3 parts:
1. a patch
2. a perl script (acpolish)
plural).
configure scripts etc.
added by acpolish.
To apply this:
./rtems-polish.sh
Later:
cvs add contrib
cvs add contrib/acpolish
cvs commit
and automake.
reorg-bsp_specs.sh script.
significantly.
