* shmsupp/Makefile.am: Cosmetics.
* vectors/Makefile.am: Cosmetics.
* shmsupp/Makefile.am: Remove all-local: $(ARCH).
* console/console-io.c, include/bsp.h, include/coverhd.h,
shmsupp/addrconv.c, shmsupp/getcfg.c, shmsupp/lock.c,
shmsupp/mpisr.c, startup/bspclean.c, startup/bspstart.c,
startup/linkcmds, startup/setvec.c, tools/psim, tools/runtest,
vectors/vectors.S: URL for license changed.
shmsupp/Makefile.am: Reflect having moved automake.
* shmsupp/Makefile.am: Don't include @RTEMS_BSP@.cfg.
* vectors/Makefile.am: Don't include @RTEMS_BSP@.cfg.
* shmsupp/Makefile.am: Use .$(OBJEXT) instead of .o.
* startup/bspstart.c: Include <rtems/bspIo.h>.
* vectors/align_h.S: Use <> instead of "" for include files.
* vectors/vectors.S: Include <bsp.h> to get PPC_VECTOR_FILE_BASE.
process was captured as PR50.
* vectors/align_h.S: Added ppc405 support.
vectors/Makefile.am, wrapup/Makefile.am: Include compile.am
converted to automake.
dependencies of "Makefile".
--enable-maintainer-mode.
future.
cd <rtems-source-tree>
this week until now.
It consists of 3 parts:
1. a patch
2. a perl script (acpolish)
plural).
configure scripts etc.
added by acpolish.
To apply this:
./rtems-polish.sh
Later:
cvs add contrib
cvs add contrib/acpolish
cvs commit
