path: root/c/src/lib/libbsp/powerpc/psim/tools/psim-top.in (follow)
* 2011-01-28 Joel Sherrill <joel.sherrilL@OARcorp.com>Joel Sherrill2011-01-281-1/+1
| | | | | | | | | | | | | | | | | | | | | | | | | | | * beatnik/include/bsp.h, beatnik/irq/irq.h, beatnik/pci/gt_pci_init.c, ep1a/console/polled_io.c, ep1a/irq/openpic_xxx_irq.c, gen5200/include/irq.h, gen5200/irq/irq.c, gen5200/startup/bspstart.c, haleakala/irq/irq.c, mbx8xx/irq/irq.c, mbx8xx/irq/irq.h, motorola_powerpc/include/bsp.h, mpc8260ads/irq/irq.c, mpc8260ads/irq/irq.h, mvme3100/include/bsp.h, mvme3100/irq/irq.h, mvme3100/start/start.S, mvme5500/include/bsp.h, mvme5500/irq/irq.h, psim/include/bsp.h, psim/include/coverhd.h, psim/irq/irq.h, psim/shmsupp/addrconv.c, psim/shmsupp/getcfg.c, psim/startup/linkcmds, psim/tools/psim-gdb-top.in, psim/tools/psim-top.in, psim/tools/runtest-top.in, qemuppc/irq/irq.h, score603e/irq/irq.c, shared/bootloader/bootldr.h, shared/bootloader/em86.c, shared/bootloader/em86real.S, shared/bootloader/exception.S, shared/bootloader/head.S, shared/bootloader/lib.c, shared/bootloader/misc.c, shared/bootloader/mm.c, shared/bootloader/pci.c, shared/console/console.c, shared/console/consoleIo.h, shared/console/inch.c, shared/console/keyboard.h, shared/console/polled_io.c, shared/irq/i8259.c, shared/irq/irq.h, shared/irq/openpic_i8259_irq.c, shared/motorola/motorola.c, shared/motorola/motorola.h, shared/openpic/openpic.c, shared/openpic/openpic.h, shared/pci/pci.c, shared/residual/residual.c, shared/start/start.S, ss555/irq/irq.h: Fix typo where license said found in found in.
* 2009-09-11 Till Straumann <Till.Straumann@TU-Berlin.de>Till Straumann2009-09-111-3/+6
| | | | | | | | | | | | | | | | * psim-top.in, psim-bottom: Added support for options -d (print device tree and exit), -h (usage info) and -n (enable NIC support). * psim-gdb-bottom: Added support for options -s (force sysv IPC), -h (usage info) and -n (enable NIC support). Allow user to override GDB variable from environment. * psim-shared: cat NIC properties into device file if the user had specified '-n'. * runtest-top.in: removed unsupported options -o, -d from usage info.
* 2008-12-04 Joel Sherrill <joel.sherrill@oarcorp.com>Joel Sherrill2008-12-041-3/+1
| | | | | | * psim-bottom, psim-gdb-bottom, psim-gdb-top.in, psim-shared, psim-top.in: Clean up and works better. Uses argv[0] to override configured target name.
* 2008-12-04 Joel Sherrill <joel.sherrill@oarcorp.com>Joel Sherrill2008-12-041-0/+1
| | | | | | | | * psim-bottom, psim-gdb-bottom, psim-shared, psim-top.in: Add ability to force psim configuration to include System V IPC devices even when the test does not appear to be multiprocessing. This is used by some RTEMS application developers for system simulation and could be used to simulate a framebuffer if a UNIX process mirrored the buffer.
* 2008-09-05 Joel Sherrill <joel.sherrill@oarcorp.com>Joel Sherrill2008-09-051-1/+3
| | | | | * psim-shared, psim-top.in, runtest-bottom, runtest-top.in: Now running mptests.
* 2008-09-03 Joel Sherrill <joel.sherrill@oarcorp.com>Joel Sherrill2008-09-031-0/+41
* Makefile.am, configure.ac: Rework psim scripts to share code for creating device trees and actually running the tests. Overhaul the device tree generated to always include a block of Flash and a Real-Time Clock. When running MP tests enable the shared memory and semaphore devices. * psim-bottom, psim-gdb-bottom, psim-gdb-top.in, psim-shared, psim-top.in, runtest-bottom, runtest-top.in: New files. * psim, psim-gdb, runtest: Removed.
