* shmsupp/Makefile.am: Use .$(OBJEXT) instead of .o.
* shmsupp/lock.c, shmsupp/mpisr.c: Fixed typo.
vectors/Makefile.am, wrapup/Makefile.am: Include compile.am
converted to automake.
Renamed file shmsupp/intr.c in some BSPs to shmsupp/cause_intr.c to
avoid conflict with rtems/src/intr.c (Classic API Interrupt Manager).
dependencies of "Makefile".
--enable-maintainer-mode.
future.
cd <rtems-source-tree>
this week until now.
It consists of 3 parts:
1. a patch
2. a perl script (acpolish)
plural).
configure scripts etc.
added by acpolish.
To apply this:
./rtems-polish.sh
Later:
cvs add contrib
cvs add contrib/acpolish
cvs commit
