* beatnik/include/bsp.h, beatnik/irq/irq.h, beatnik/pci/gt_pci_init.c,
ep1a/console/polled_io.c, ep1a/irq/openpic_xxx_irq.c,
gen5200/include/irq.h, gen5200/irq/irq.c, gen5200/startup/bspstart.c,
haleakala/irq/irq.c, mbx8xx/irq/irq.c, mbx8xx/irq/irq.h,
motorola_powerpc/include/bsp.h, mpc8260ads/irq/irq.c,
mpc8260ads/irq/irq.h, mvme3100/include/bsp.h, mvme3100/irq/irq.h,
mvme3100/start/start.S, mvme5500/include/bsp.h, mvme5500/irq/irq.h,
psim/include/bsp.h, psim/include/coverhd.h, psim/irq/irq.h,
psim/shmsupp/addrconv.c, psim/shmsupp/getcfg.c,
psim/startup/linkcmds, psim/tools/psim-gdb-top.in,
psim/tools/psim-top.in, psim/tools/runtest-top.in, qemuppc/irq/irq.h,
score603e/irq/irq.c, shared/bootloader/bootldr.h,
shared/bootloader/em86.c, shared/bootloader/em86real.S,
shared/bootloader/exception.S, shared/bootloader/head.S,
shared/bootloader/lib.c, shared/bootloader/misc.c,
shared/bootloader/mm.c, shared/bootloader/pci.c,
shared/console/console.c, shared/console/consoleIo.h,
shared/console/inch.c, shared/console/keyboard.h,
shared/console/polled_io.c, shared/irq/i8259.c, shared/irq/irq.h,
shared/irq/openpic_i8259_irq.c, shared/motorola/motorola.c,
shared/motorola/motorola.h, shared/openpic/openpic.c,
shared/openpic/openpic.h, shared/pci/pci.c,
shared/residual/residual.c, shared/start/start.S, ss555/irq/irq.h:
Fix typo where license said found in found in.
* console/consupp.S, irq/irq.h, irq/irq_init.c: Add CVS Id string.
* Makefile.am, preinstall.am, irq/no_pic.c (REMOVED),
use openpic from 'shared' area instead of no_pic.
* inlude/psim.h:
Added 'extern' declaration for (linker-script defined) RamBase
and RamSize symbols. Let CPP macros expand to these symbols
instead of static constants.
Added register definitions for OpenPIC in the register area.
Added register definitions for ethernet controller in the register
area.
* startup/linkcmds: Increased RamSize to 16M. Increased 'RAM'
memory region to 32M (there is really no disadvantage in making
this large). Added comment explaining the inter-relation between
RamSize, the size of the memory region, the device-tree property
"oea-memory-size" and the DBAT setting.
* tools/psim-shared: Try to determine RamSize from executable
and set 'oea-memory-size' accordingly. May be overridden if 'RAM_SIZE'
envvar is set.
Added openpic to device-tree.
Added ethernet controller to device-tree (commented because a PSIM
patch is currently required to use this device).
* startup/bspstart: Increase DBAT0 mapping to size of 32M.
* irq/irq_init.c: Fix warnings.
* Makefile.am, irq/irq_init.c: use vector/interrupt
support from libcpu/powerpc/new-exceptions/bspsupport.
* ep1a/irq/irq.c, gen5200/irq/irq.c, gen83xx/irq/irq_init.c,
mbx8xx/irq/irq.c, mpc8260ads/irq/irq.c, mvme5500/irq/irq.c,
psim/irq/no_pic.c, score603e/irq/irq.c, shared/irq/irq_supp.h,
shared/irq/openpic_i8259_irq.c, virtex/irq/irq_init.c:
let C_dispatch_irq_handler() return zero to indicate to
low-level exception handling code that the exception
was handled (not used yet).
* irq/irq_init.c: Add missing vectDesc variable.
* irq/irq_init.c: Spacing.
* irq/irq_init.c: removed unnecessary code (alredy
done by shared/irq/irq.c).
* Makefile.am, irq/no_pic.c: Spacing.
* irq/no_pic.c: use new inline routine exported by
shared/irq/irq_supp.h for scanning the handler list.
* irq/irq_init.c: removed irrelevant comment.
* irq/irq.h, irq/no_pic.c: some more changes to let
using shared/irq/irq.c work.
* Makefile.am, irq/irq.h, irq/no_pic.c: install
and use new <irq/irq_supp.h> header.
* irq/irq.h, irq/irq_init.c: Removed the definition
of ASM_IRQ_VECTOR_BASE; this symbol was only use to
initialize the irqBase member of the rtems_irq_global_settings
struct. However, irqBase is an rtems_irq_symbolic_name,
so using BSP_LOWEST_OFFSET is more appropriate.
* irq/irq.h, irq/irq.c (removed), irq/no_pic.c (added),
irq/irq_init.c, Makefile.am: The PSIM BSP (currently)
has no support for an interrupt controller or interrupts
other than the decrementer. Removed all definitions for PCI + ISA
interrupts and all unnecessary code (leftovers from copying).
Separated PIC-specific bits into 'no_pic.c' which allows us
to use 'irq.c' (i.e., more code) from 'shared'.
* startup/bspstart.c, Makefile.am: Initialize BATs and enable MMU
to come closer to what other BSPs do. This allows us to use the
shared irq_asm.S. No more individual assembly code :-)
* ep1a/irq/irq.c, gen5200/irq/irq.c, mbx8xx/irq/irq.c,
mpc8260ads/irq/irq.c, mvme5500/irq/irq.c, psim/irq/irq.c,
score603e/irq/irq.c, shared/irq/irq.c:
test for non-NULL-ness before calling 'on'/'off'
methods so that users don't have to provide
no-ops if they don't want this feature.
PR 1257/bsps
* irq/irq.c: Code outside of cpukit should use the public API for
rtems_interrupt_disable/rtems_interrupt_enable. By bypassing the
public API and directly accessing _CPU_ISR_Disable and
_CPU_ISR_Enable, they were bypassing the compiler memory barrier
directive which could lead to problems. This patch also changes the
type of the variable passed into these routines and addresses minor
style issues.
* Makefile.am, irq/irq.h: Merge c_rtems_main() into boot_card(). This
eliminated a file and simplified initialization.
* mvme5500/irq/irq.h, psim/irq/irq.h, shared/console/uart.c,
shared/irq/irq.h: Renamed BSP_ISA_UART_COMx_IRQ -> BSP_UART_COMx_IRQ
(uart driver is ISA independent).
Removed ugly #ifdef mvme2100. Added test for
BSP_UART_USE_SHARED_IRQS symbol which a BSP can define to request
that the serial interrupt be shared.
* irq/irq.c, irq/irq.h: Modified to use rtems/irq.h.
PR 779/bsp
* irq/irq.c, irq/irq.h, irq/irq_init.c: add parameter to new exception
interrupt handlers in powerpc bsps
PR 581/bsps
* Makefile.am, bsp_specs, configure.ac, include/bsp.h, include/tm27.h,
start/start.S, startup/bspstart.c, startup/linkcmds,
tools/Makefile.am, tools/psim, vectors/vectors.S, wrapup/Makefile.am:
Convert PSIM to new exception model.
* irq/irq.c, irq/irq.h, irq/irq_asm.S, irq/irq_init.c: New files.
* startup/setvec.c, timer/timer.c: Removed.
