Reflect changes to bsp.am.
* bsp_specs: Remove *lib:.
* console/console-io.c, include/bsp.h, include/coverhd.h,
shmsupp/addrconv.c, shmsupp/getcfg.c, shmsupp/lock.c,
shmsupp/mpisr.c, startup/bspclean.c, startup/bspstart.c,
startup/linkcmds, startup/setvec.c, tools/psim, tools/runtest,
vectors/vectors.S: URL for license changed.
* startup/bspstart.c: Removed incorrect statement about copyright
assignment.
shmsupp/Makefile.am: Reflect having moved automake.
* startup/linkcmds*: Add FreeBSD sysctl() sections.
* shmsupp/Makefile.am: Don't include @RTEMS_BSP@.cfg.
* vectors/Makefile.am: Don't include @RTEMS_BSP@.cfg.
* .cvsignore: Reformat.
Add autom4te*cache.
Remove autom4te.cache.
* clock/clock.c: Disabled use of fast idle since it seems broken
with gcc 3.2.
* shmsupp/Makefile.am: Use .$(OBJEXT) instead of .o.
* startup/Makefile.am: Add bsplib_DATA = linkcmds device-tree.
* startup/linkcmds: In support of gcc 3.1, added one of more
of the sections .jcr, .rodata*, .data.*, .gnu.linkonce.s2.*,
.gnu.linkonce.sb2.*, and .gnu.linkonce.s.*. Spacing corrections
and direction of segments to memory regions may also have been
addressed. This was a sweep across all BSPs.
* startup/bspstart.c: Include <rtems/bspIo.h>.
* vectors/align_h.S: Use <> instead of "" for include files.
* startup/linkcmds: Per PR170, PR171, and PR172 add .eh_frame
* vectors/Makefile.am: Remove AUTOMAKE_OPTIONS.
* console/console-io.c: Include rtems/bspIo.h instead of bspIo.h.
* vectors/vectors.S: Include <bsp.h> to get PPC_VECTOR_FILE_BASE.
* Makefile.am: Add @exceptions@ to SUBDIRS.
* configure.ac: Apply RTEMS_BSPOPTS_*(*) to merge-in settings from
make/custom/psim.cfg;
Remove RTEMS_OUTPUT_BUILD_SUBDIRS;
Add RTEMS_PPC_EXCEPTIONS([old]).
* include/Makefile.am: include force-preinstall.am.
* wrapup/Makefile.am: Apply @exceptions@.
* console/console-io.c: Fix incorrect comment.
process was captured as PR50.
* vectors/align_h.S: Added ppc405 support.
* startup/linkcmds: Added _init and _fini.
* shmsupp/lock.c, shmsupp/mpisr.c: Fixed typo.
* configure.in: Remove.
* wrapup/Makefile: Use GENERIC_FILES = to make automake-1.5 happy.
* clock/clock.c: Ensure that clock ticks are long enough to
make forward progress. This was modified to improve results
on the RTEMS tests and the ACATS.
* startup/linkcmds: Modified to work better with gcc 2.8.1 and
gnat 3.13p.
* clock/clock.c: Use shared clock driver shell.
* console/console.c: Removed. Now use shared polling shell.
* console/console-io.c: New file.
* console/Makefile.am: Correct to use shared polling shell.
* startup/bspstart.c: Remove all fast idle references.
* timer/timer.c: Removed incorrect comments about ERC32.
* configure.in, Makefile.am: ACLOCAL_AMFLAGS= -I $(RTEMS_TOPdir)/macros.
vectors/Makefile.am, wrapup/Makefile.am: Include compile.am
