* acinclude.m4: Remove dmv177 and ppcn_60x.
* dmv177/.cvsignore, dmv177/ChangeLog, dmv177/Makefile.am,
dmv177/QUIRKS, dmv177/README, dmv177/README.net, dmv177/STATUS,
dmv177/bsp_specs, dmv177/cable.doc, dmv177/configure.ac,
dmv177/times, dmv177/clock/clock.c, dmv177/console/conscfg.c,
dmv177/console/debugio.c, dmv177/include/.cvsignore,
dmv177/include/bsp.h, dmv177/include/dmv170.h, dmv177/include/tm27.h,
dmv177/scv64/scv64.c, dmv177/sonic/dmvsonic.c, dmv177/start/start.S,
dmv177/startup/bspclean.c, dmv177/startup/bspstart.c,
dmv177/startup/genpvec.c, dmv177/startup/linkcmds,
dmv177/startup/setvec.c, dmv177/startup/vmeintr.c,
dmv177/timer/timer.c, dmv177/tod/todcfg.c, ppcn_60x/.cvsignore,
ppcn_60x/ChangeLog, ppcn_60x/Makefile.am, ppcn_60x/README,
ppcn_60x/STATUS, ppcn_60x/bsp_specs, ppcn_60x/configure.ac,
ppcn_60x/clock/clock.c, ppcn_60x/console/config.c,
ppcn_60x/console/console.c, ppcn_60x/console/console.h,
ppcn_60x/console/debugio.c, ppcn_60x/console/i8042.c,
ppcn_60x/console/i8042_p.h, ppcn_60x/console/i8042vga.c,
ppcn_60x/console/i8042vga.h, ppcn_60x/console/ns16550cfg.c,
ppcn_60x/console/ns16550cfg.h, ppcn_60x/console/vga.c,
ppcn_60x/console/vga_p.h, ppcn_60x/console/z85c30cfg.c,
ppcn_60x/console/z85c30cfg.h, ppcn_60x/include/.cvsignore,
ppcn_60x/include/bsp.h, ppcn_60x/include/extisrdrv.h,
ppcn_60x/include/nvram.h, ppcn_60x/include/pci.h,
ppcn_60x/include/tm27.h, ppcn_60x/network/amd79c970.c,
ppcn_60x/network/amd79c970.h, ppcn_60x/nvram/ds1385.h,
ppcn_60x/nvram/mk48t18.h, ppcn_60x/nvram/nvram.c,
ppcn_60x/nvram/prepnvr.h, ppcn_60x/nvram/stk11c68.h,
ppcn_60x/pci/pci.c, ppcn_60x/start/start.S,
ppcn_60x/startup/bspclean.c, ppcn_60x/startup/bspstart.c,
ppcn_60x/startup/bsptrap.S, ppcn_60x/startup/genpvec.c,
ppcn_60x/startup/linkcmds, ppcn_60x/startup/rtems-ctor.cc,
ppcn_60x/startup/setvec.c, ppcn_60x/startup/spurious.c,
ppcn_60x/startup/swap.c, ppcn_60x/timer/timer.c, ppcn_60x/tod/cmos.h,
ppcn_60x/tod/tod.c, ppcn_60x/universe/universe.c,
ppcn_60x/vectors/README, ppcn_60x/vectors/align_h.S,
ppcn_60x/vectors/vectors.S: Removed.
* clock/clock.c: Eliminate warning for duplicate definition of
PPC_Set_decrementer.
* include/bsp.h, pci/pci.c, startup/bspstart.c: Make PCI initialize
function part of the unified PCI API as pci_initialize().
* configure.ac: Remove argument from RTEMS_PPC_EXCEPTIONS.
* startup/spurious.c: Merge ppc603 and ppc603e.
Remove digits (Unused).
* Makefile.am: Fix typo in previous patch.
* Makefile.am: Merge-in wrapup/Makefile.am.
* wrapup/Makefile.am: Remove.
* vectors/vectors.S: Remove PPC_ABI_POWEROPEN.
* vectors/vectors.S: Remove PPC_ABI_GCC27.
* vectors/vectors.S: Remove XCOFF support.
* Makefile.am: Use ../../shared/tod.h instead of include/tod.h.
* console/config.c: Remove typos from 2005-01-04 changes.
* include/tod.h: Remove.
* Makefile.am: Eliminate CFLAGS_OPTIMIZE_V.
* console/config.c: Remove warnings.
* Makefile.am, wrapup/Makefile.am: Remove build-variant support.
PR 610/bsps
* Makefile.am: Add include/tm27.h, Cosmetics.
* include/tm27.h: Final cosmetics.
* include/tm27.h: New.
PR 613/bsps
PR 614/bsps
* vectors/vectors.S: Include <rtems/asm.h> instead of <asm.h>.
* startup/genpvec.c: Include <rtems/chain.h> instead of <chain.h>.
* console/i8042.c: Include <rtems/ringbuf.h> instead of <ringbuf.h>.
* console/console.h: Include <rtems/ringbuf.h> instead of <ringbuf.h>.
* clock/clock.c, console/config.c, console/console.c,
console/debugio.c, console/i8042.c, console/ns16550cfg.c,
console/ns16550cfg.h, console/vga.c, console/vga_p.h,
console/z85c30cfg.c, console/z85c30cfg.h, include/bsp.h,
include/nvram.h, include/pci.h, network/amd79c970.c,
network/amd79c970.h, nvram/mk48t18.h, nvram/nvram.c,
nvram/stk11c68.h, pci/pci.c, startup/bspstart.c, startup/genpvec.c,
startup/spurious.c, startup/swap.c, timer/timer.c, tod/cmos.h,
tod/tod.c, universe/universe.c: Convert to using c99 fixed size
types.
* Makefile.am: Reflect changes to bsp.am.
Preinstall dist_project_lib*.
* Makefile.am: Use CPPASCOMPILE instead of CCASCOMPILE.
* wrapup/Makefile.am: Convert to automake-building rules.
network/Makefile.am, nvram/Makefile.am, pci/Makefile.am,
startup/Makefile.am, timer/Makefile.am, tod/Makefile.am,
universe/Makefile.am, vectors/Makefile.am. Use automake compilation
rules.
* clock/Makefile.am, console/Makefile.am, network/Makefile.am,
nvram/Makefile.am, pci/Makefile.am, startup/Makefile.am,
timer/Makefile.am, tod/Makefile.am, universe/Makefile.am,
vectors/Makefile.am: Remove.
* Makefile.am: Merge-in start/Makefile.am.
* start/Makefile.am: Remove.
* wrapup/Makefile.am: Reflect changes to
../support/*exception_processing/*.
* configure.ac: Add nostdinc to AUTOMAKE_OPTIONS.
Add RTEMS_PROG_CCAS.
* wrapup/Makefile.am: Reflect changes to libcpu.
* start/Makefile.am: Ditto.
* startup/Makefile.am: Ditto.
* wrapup/Makefile.am: Eliminate $(LIB).
Use noinst_DATA to trigger building libbsp.a.
* clock/Makefile.am: Eliminate VPATH.
* console/Makefile.am: Eliminate VPATH.
* network/Makefile.am: Eliminate VPATH.
* nvram/Makefile.am: Eliminate VPATH.
* pci/Makefile.am: Eliminate VPATH.
* start/Makefile.am: Eliminate VPATH.
* startup/Makefile.am: Eliminate VPATH.
* timer/Makefile.am: Eliminate VPATH.
* tod/Makefile.am: Eliminate VPATH.
* universe/Makefile.am: Eliminate VPATH.
* vectors/Makefile.am: Eliminate VPATH.
* network/Makefile.am: Cosmetics.
* nvram/Makefile.am: Cosmetics.
* pci/Makefile.am: Cosmetics.
* tod/Makefile.am: Cosmetics.
* universe/Makefile.am: Cosmetics.
* vectors/Makefile.am: Cosmetics.
* nvram/Makefile.am: Remove all-local: $(ARCH).
* pci/Makefile.am: Remove all-local: $(ARCH).
* tod/Makefile.am: Remove all-local: $(ARCH).
* universe/Makefile.am: Remove all-local: $(ARCH).
