dependencies of "Makefile".
--enable-maintainer-mode.
ncurses, and zlib for RTEMS.
link even if they do not actually support Ada interrupts.
future.
cd <rtems-source-tree>
by Andrew Bray <andy@madhouse.demon.co.uk>.
all bsp_specs.
In your various bsp_specs files, even when ecrti.o is defined as a
startfile, ecrtn.o is not defined as an endfile. Instead it seems to
be in the library list - untidy.
this week until now.
It consists of 3 parts:
1. a patch
2. a perl script (acpolish)
plural).
configure scripts etc.
added by acpolish.
To apply this:
./rtems-polish.sh
Later:
cvs add contrib
cvs add contrib/acpolish
cvs commit
and automake.
reorg-bsp_specs.sh script.
significantly.
ppc403 interrupt control libcpu component.
<ian@airs.com>:
The pc386 linker scripts omits .gnu.linkonce.r* sections. It's not a
big deal, but they should be treated like .rodata sections. ELF
versions of g++ generate them for static constants defined in template
classes, such as string::npos.
by newlib.
component.
based on the GNU tools. This usually involved correcting the
type of bsp_start(), bsp_cleanup(), adjusting the start code to
call the right start routine (the shared boot_card()), and then
removing code from bsp_start() which was performed in the new
boot_card()/main() path.
"gmake debug".
subdirectory Makefiles.
used.
individual Makefile.
problem (reported by Eric)
interpreted at the right point per Eric Norum's discovery:
The problem with the my previous `fix' for adding linker commands
was with the ordering of the options to the linker.
For example, to make a larger heap size, the application Makefile would
CFLAGS_LD = -Wl,--defsym -Wl,HeapSize=0x40000
The command passed to the linker would be :
m68k-rtems-ld .... -T xxx/linkcmds .... --defsym HeapSize=0x40000 .....
This doesn't work because the script in linkcmds inserts a default
value for HeapSize if HeapSize is not defined by the time the linker
looks at the linkcmds script.
The solution seems to be to move the -T linkcmds%s in the bsp_specs
file out of the link specfication and into the lib specification -- a
little unorthodox, perhaps, but it seems to work!
switch which lets the user specify a different linker script.
to lib/include.
returned an error to using a single shared copy of this file.
be resolved.
only required in a multiprocessor system. It was replace by the MPCI
Receive Server. As a result, the CPU Table field for extra stack for
the SYSI task was changed to be extra stack for the MPCI Receive Server.
