1998-12-14 | Patch from Ralf Corsepius <corsepiu@faw.uni-ulm.de> to rename all | Joel Sherrill | 1 | -289/+0 | |
.s files to .S in conformance with GNU conventions. This is a minor step along the way to supporting automake. | |||||
1998-03-21 | Switch to using a shared main() for all of the embedded BSPs | Joel Sherrill | 1 | -2/+2 | |
based on the GNU tools. This usually involved correcting the type of bsp_start(), bsp_cleanup(), adjusting the start code to call the right start routine (the shared boot_card()), and then removing code from bsp_start() which was performed in the new boot_card()/main() path. | |||||
1995-12-20 | changes remerged after lost in disk crash -- recovered from snapshot, ↵ | Joel Sherrill | 1 | -5/+7 | |
partially recovered working tree, etc | |||||
1995-10-06 | fixed missing CVS IDs | Joel Sherrill | 1 | -0/+2 | |
1995-08-22 | Added file .. fixed RCS Id | Joel Sherrill | 1 | -24/+60 | |
1995-08-22 | fixed RCS Id | Joel Sherrill | 1 | -0/+249 | |
