* startup/linkcmds: Added lines so DWARF debug information
would be available. Otherwise gdb complains that the offsets
for the debug info are incorrect and doesn't load the files.
* dlentry/Makefile.am, flashentry/Makefile.am, startup/Makefile.am,
