Update #2833.
Update #2825.
There must be an isync after the mtmsr to ensure that the AltiVec is
enabled for subsequent instructions.
Use thread local variable instead of task variable.
Update #2494.
warnings
Update #2408.
Update #2408.
The size of the sample executables without this option were:
193649 21100 15365 230114 382e2 base_sp.exe
181425 19928 15325 216678 34e66 hello.exe
174257 19452 12097 205806 323ee minimum.exe
613505 89234 27649 730388 b2514 fileio.exe
216977 22848 15469 255294 3e53e nsecs.exe
226897 33644 16033 276574 4385e paranoia.exe
196849 21268 15397 233514 3902a ticker.exe
196401 22044 19173 237618 3a032 unlimited.exe
947265 209858 23001 1180124 1201dc cxx_iostream.exe
284753 39784 16037 340574 5325e cdtest.exe
263073 31692 17189 311954 4c292 capture.exe
The size of the sample executables with this option enabled were:
168257 17808 15281 201346 31282 base_sp.exe
154113 16692 15201 186006 2d696 hello.exe
124545 14548 11713 150806 24d16 minimum.exe
578049 83946 27273 689268 a8474 fileio.exe
192337 19556 15385 227278 377ce nsecs.exe
201249 30328 15913 247490 3c6c2 paranoia.exe
171681 17976 15313 204970 320aa ticker.exe
169441 18732 19049 207222 32976 unlimited.exe
604757 47466 22093 674316 a4a0c cxx_iostream.exe
260569 27820 15921 304310 4a4b6 cdtest.exe
237217 28200 17105 282522 44f9a capture.exe
Notepads where a feature of RTEMS' tasks that simply functioned in
the same way as POSIX keys or threaded local storage (TLS). They were
introduced well before per task variables, which are also deprecated,
and were barely used in favor of their POSIX alternatives.
In addition to their scarce usage, Notepads took up unnecessary memory.
For each task:
- 16 32-bit integers were allocated.
- A total of 64 bytes per task per thread.
This is especially critical in low memory and safety-critical applications.
They are also defined as uint32_t, and therefore are not guaranteed to
hold a pointer.
Lastly, they are not portable solutions for SMP and uniprocessor systems,
like POSIX keys and TLS.
updates #2493.
Update #2408.
Update #2408.
do
echo $b
# echo $g
-i $b
done
Drop the <rtems/score/percpu.h> include since this file exposes a lot of
implementation details.
updated #2306.
Also use the const qualifier on the address pointer's target in in_*()
Closes #2128
Include <sys/param.h> if necessary to get the MIN()/MAX() macros.
warning and clean up
Fix build error introduced in f535fe5311978af53635c2da8e5cb10ef9d78802.
Instead of SPRG0 (= special purpose register 272) use the new global
symbol _PPC_INTERRUPT_DISABLE_MASK to store the interrupt disable mask.
The benefit is that it is now possible to disable interrupts without
further run-time initialization in boot_card().
At least on Freescale e500 cores this leads also to a faster execution
since the mfmsr and mfspr instruction require four cycles to complete.
The instructions to load the mask value can execute while the mfmsr is
in progress.
sequence must be executed in MOTLoad before booting RTEMS to remove its network interface interrupt handlers, lest memory corruption occur
Do not return from rtems_initialize_start_multitasking() and call
rtems_fatal() instead with a fatal source of RTEMS_FATAL_SOURCE_EXIT and
a fatal code with the exit status.
Remove all bsp_cleanup() functions. The boot_card() is now a no return
function.
The Data Access Register (DAR) is not saved in the exception prologue.
Add reserved system events RTEMS_EVENT_SYSTEM_NETWORK_SBWAIT and
RTEMS_EVENT_SYSTEM_NETWORK_SOSLEEP.
Add and use rtems_bsdnet_event_send().
Conflicts:
+ libbsp/sparc/shared/include/pci.h was largely a copy of
an older version of the cpukit pci.h. Removed much of the
contents and included <rtems/pci.h>.
+ sparc/*/pci*.c - Move to <rtems/pci.h> required updating
to use uint32_t for dword accesses.
+ Rename PCI_MULTI_FUNCTION to PCI_HEADER_TYPE_MULTI_FUNCTION
+ Define PCI_HEADER_TYPE_MULTI_FUNCTION in cpukit pci.h and remove
PCI_MULTI_FUNCTION definitions in C files.
+ Move PCI_INVALID_VENDORDEVICEID definitions from various C files
to cpukit pci.h
