Do not return from rtems_initialize_start_multitasking() and call
rtems_fatal() instead with a fatal source of RTEMS_FATAL_SOURCE_EXIT and
a fatal code with the exit status.
Remove all bsp_cleanup() functions. The boot_card() is now a no return
function.
The Data Access Register (DAR) is not saved in the exception prologue.
Add reserved system events RTEMS_EVENT_SYSTEM_NETWORK_SBWAIT and
RTEMS_EVENT_SYSTEM_NETWORK_SOSLEEP.
Add and use rtems_bsdnet_event_send().
Conflicts:
+ libbsp/sparc/shared/include/pci.h was largely a copy of
an older version of the cpukit pci.h. Removed much of the
contents and included <rtems/pci.h>.
+ sparc/*/pci*.c - Move to <rtems/pci.h> required updating
to use uint32_t for dword accesses.
+ Rename PCI_MULTI_FUNCTION to PCI_HEADER_TYPE_MULTI_FUNCTION
+ Define PCI_HEADER_TYPE_MULTI_FUNCTION in cpukit pci.h and remove
PCI_MULTI_FUNCTION definitions in C files.
+ Move PCI_INVALID_VENDORDEVICEID definitions from various C files
to cpukit pci.h
All constants that should have been in cpukit pci.h were moved there.
One naming style was corrected. This impacted if_wm.c.
All other contents were the same as powerpc/shared/pci.h so BSP
specific pci.h could be eliminated.
* start/start.S: Tag TOS with a NULL pointer
(help terminate when walking the stack).
PR 1824/cpukit
* startup/bspclean.c: Return exit/shutdown status back to boot_card().
boot_card() propagates this to bsp_cleanup() and returns it to the
assembly that started the application. bsp_cleanup() prototype
changed.
PR 1786/bsps
* Makefile.am: Add support for Altivec.
* startup/bspstart.c, Makefile.am: Use shared/startup/zerobss.c instead.
* make/custom/mvme5500.cfg: Change CPU_CFLAGS to
"-mcpu=7450 -mtune=7450 -Dmpc7455"
* irq/BSP_irq.c, pci/detect_host_bridge.c, pci.c, pcifinddevice.c:
Remove warnings.
* vme/VMEConfig.h, include/bsp.h: use VME shared IRQ handlers.
* network/if_100MHz/GT64260eth.c: Recycle the Rx mbuf if there
is any Rx error.
* configure.ac: Use standard cache BSP options.
PR1797/bsps: Applied cleaned-up version of Kate's patch.
CONFIGURE_MALLOC_BSP_SUPPORTS_SBRK is now a 'bspopts.h'
setting and as such configurable.
* include/bsp.h, include/tm27.h:
* beatnik/include/bsp.h, beatnik/irq/irq.h, beatnik/pci/gt_pci_init.c,
ep1a/console/polled_io.c, ep1a/irq/openpic_xxx_irq.c,
gen5200/include/irq.h, gen5200/irq/irq.c, gen5200/startup/bspstart.c,
haleakala/irq/irq.c, mbx8xx/irq/irq.c, mbx8xx/irq/irq.h,
motorola_powerpc/include/bsp.h, mpc8260ads/irq/irq.c,
mpc8260ads/irq/irq.h, mvme3100/include/bsp.h, mvme3100/irq/irq.h,
mvme3100/start/start.S, mvme5500/include/bsp.h, mvme5500/irq/irq.h,
psim/include/bsp.h, psim/include/coverhd.h, psim/irq/irq.h,
psim/shmsupp/addrconv.c, psim/shmsupp/getcfg.c,
psim/startup/linkcmds, psim/tools/psim-gdb-top.in,
psim/tools/psim-top.in, psim/tools/runtest-top.in, qemuppc/irq/irq.h,
score603e/irq/irq.c, shared/bootloader/bootldr.h,
shared/bootloader/em86.c, shared/bootloader/em86real.S,
shared/bootloader/exception.S, shared/bootloader/head.S,
shared/bootloader/lib.c, shared/bootloader/misc.c,
shared/bootloader/mm.c, shared/bootloader/pci.c,
shared/console/console.c, shared/console/consoleIo.h,
shared/console/inch.c, shared/console/keyboard.h,
shared/console/polled_io.c, shared/irq/i8259.c, shared/irq/irq.h,
shared/irq/openpic_i8259_irq.c, shared/motorola/motorola.c,
shared/motorola/motorola.h, shared/openpic/openpic.c,
shared/openpic/openpic.h, shared/pci/pci.c,
shared/residual/residual.c, shared/start/start.S, ss555/irq/irq.h:
Fix typo where license said found in found in.
PR 1684/bsps
* startup/bspstart.c: Add BSP_poll_char.
* configure.ac: Remove AC_CHECK_SIZEOF([void *]).
* configure.ac: Added AC_CHECK_SIZEOF macro.
PR 1483/cpukit
* pci/pci.c: Rename pci_config into rtems_pci_config_t.
* irq/BSP_irq.c, network/if_100MHz/GT64260eth.c,
network/if_1GHz/if_wm.c, network/if_1GHz/pci_map.c,
startup/bspstart.c: Add missing prototypes.
Adjust bogus types. Remove unused vars.
* make/custom/mvme5500.cfg: Remove RTEMS_BSP_FAMILY.
* start/start.S, startup/bspstart.c:
let 'save_boot_params()' return a pointer to the commandline
saved by the BSP and pass this pointer on to 'boot_card()'.
* startup/bspstart.c: Remove nested externs.
* startup/bspstart.c: Remove __RTEMS_APPLICATION__
* make/custom/mvme5500.cfg: New (relocated from /make/custom).
* network/if_100MHz/GT64260eth.c, network/if_1GHz/if_wm.c: Do not
include <sys/queue.h>. It conflicts with one from network stack.
* configure.ac: Remove RTEMS_BSP_BOOTCARD_OPTIONS.
* include/bsp.h: Eliminate BSPs defining NUMBER_OF_TERMIOS_PORTS.
Should be automatically handled by confdefs.h or the application.
* configure.ac: Rename BSP_BOOTCARD_OPTIONS to
RTEMS_BSP_BOOTCARD_OPTIONS. Add RTEMS_BSP_CLEANUP_OPTIONS so all BSPs
have the same options.
* irq/BSP_irq.c: New file.
* irq/irq.c, network/if_1GHz/POSSIBLEBUG: Removed.
* include/bsp.h, start/start.S, startup/bspstart.c:
added CONFIGURE_MALLOC_BSP_SUPPORTS_SBRK in bsp.h.
removed BSP_INIT_STACK_SIZE in bsp.h -- it uses __stack defined
by the linker script (shared/startup/linkcmds) for the initial
stack.
replaced __rtems_end+4096 with __stack in start.S
Removed legacy code in bspstart.c (inherited from old mvme2307 BSP
but not relevant to this one) that tested trapping
into PPCBug.
Changed ConfVPD_buff[] to be static and added ReadConfVPD_buf() in
bspstart.c
* start/start.S: Update for boot_card command line change.
