line option.
may suppress warnings.
erc32, imx, qoriq, etc.
* cpukit/include
* cpukit/libnetworking
* bsps/include
* bsps/@RTEMS_CPU@/include
order.
Update #3254.
Update #3254.
This collection of BSPs shared the linker script shared/startup/linkcmds.
I renamed that ot shared/startup/linkcmds.share and made a BSP family
specific startup/linkcmds. This was needed because each BSP family had
a different combination of start file name, undefined symbols, etc.
Updates #3520.
maintain.
Update #3254.
Fix build error introduced in f535fe5311978af53635c2da8e5cb10ef9d78802.
All constants that should have been in cpukit pci.h were moved there.
One naming style was corrected. This impacted if_wm.c.
All other contents were the same as powerpc/shared/pci.h so BSP
specific pci.h could be eliminated.
* Makefile.am: Cleanup ../../shared/include/bootcard.h handling.
* Makefile.am, irq/irq.c, irq/irq.h, irq/irq_init.c:
use new exception/irq support from
libcpu/powerpc/new-exceptions/bspsupport
rather than borrowing from ../shared/vectors ../shared/irq
* ChangeLog, Makefile.am, README, README.booting, README.irq,
preinstall.am, GT64260/MVME5500I2C.c, include/bsp.h, irq/irq.c,
irq/irq.h, irq/irq_init.c, pci/detect_host_bridge.c, pci/pci.c,
pci/pci_interface.c, pci/pcifinddevice.c, start/preload.S,
startup/bspclean.c, startup/bspstart.c, startup/pgtbl_activate.c,
startup/reboot.c, vectors/bspException.h, vectors/exceptionhandler.c:
Merge my improvements in this BSP including a new network
driver for the 1GHz NIC.
* network/if_100MHz/GT64260eth.c, network/if_100MHz/GT64260eth.h,
network/if_100MHz/GT64260ethreg.h, network/if_100MHz/Makefile.am,
network/if_1GHz/Makefile.am, network/if_1GHz/POSSIBLEBUG,
network/if_1GHz/if_wm.c, network/if_1GHz/if_wmreg.h,
network/if_1GHz/pci_map.c, network/if_1GHz/pcireg.h: New files.
* Makefile.am, preinstall.am, include/bsp.h,
* vme/vmeconfig.c (removed), vme/VME.h (removed):
cleaned up vme support - use files from libbsp/powerpc/shared/vme
and define BSP specifica in VMEConfig.h.
Use VME DMA support implemented by vmeUniverse and
libbsp/powerpc/shared/vme/vme_universe_dma.c
* mvme5500/vme/VMEConfig.h, mvme5500/vme/VME.h,
* mvme5500/vme/vmeconfig.c:
removed copies of vmeconfig.c, VME.h - use generic
versions instead.
need to install bsp/vme_am_defs.h
* Makefile.am: Don't include subdirs.am.
* startup/linkcmds: Removed.
* Makefile.am, start/preload.S, startup/bspstart.c: use linkcmds
from shared area - this version seemed broken anyways. Let the
preloader use the generic 'entry_point_section' rather than its own
'mvme5500_preloader_section'. Also, let zero_bss use (implicit?)
__SBSSxxx__ symbols.
* Makefile.am: Merge-in wrapup/Makefile.am.
* wrapup/Makefile.am: Remove.
* Makefile.am: Eliminate CFLAGS_OPTIMIZE_V.
* Makefile.am, wrapup/Makefile.am: Remove build-variant support.
* Makefile.am: Fix network_CPPFLAGS. Reformat.
* network/GT64260eth.c: Properly prototype GT64260eth_err().
* Makefile.am: Add missing network_CPPFLAGS.
* Makefile.am: Build networking.rel conditionally.
Reformat. Cosmetics.
* wrapup/Makefile.am: Build networking.rel conditionally.
* startup/bspstart.c: Eliminate RTEMS fixed size types.
* configure.ac: Adaptations to rtems-4.7.
* Makefile.am, wrapup/Makefile.am: Reworked.
