* | Use $(EXEEXT) [defaults to "exe"] to generate binaries | Nick Withers | 2013-08-09 | 1 | -1/+1 |
* | 2011-04-10 Kate Feng <feng@bnl.gov> | Joel Sherrill | 2011-06-17 | 1 | -4/+7 |
| | | | | | | | | | | | | | PR 1786/bsps * Makefile.am: Add support for Altivec. * startup/bspstart.c, Makefile.am: Use shared/startup/zerobss.c instead. * make/custom/mvme5500.cfg: Change CPU_CFLAGS to "-mcpu=7450 -mtune=7450 -Dmpc7455" * irq/BSP_irq.c, pci/detect_host_bridge.c, pci.c, pcifinddevice.c: Remove warnings. * vme/VMEConfig.h, include/bsp.h: use VME shared IRQ handlers. * network/if_100MHz/GT64260eth.c: Recycle the Rx mbuf if there is any Rx error. | ||||
* | 2009-10-21 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2009-10-21 | 1 | -3/+0 |
| | | | | * make/custom/mvme5500.cfg: Remove RTEMS_BSP_FAMILY. | ||||
* | 2009-10-15 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2009-10-15 | 1 | -0/+28 |
* make/custom/mvme5500.cfg: New (relocated from /make/custom). |
