* configure.ac: Use standard cache BSP options.
PR1797/bsps: Applied cleaned-up version of Kate's patch.
CONFIGURE_MALLOC_BSP_SUPPORTS_SBRK is now a 'bspopts.h'
setting and as such configurable.
* configure.ac: Remove AC_CHECK_SIZEOF([void *]).
* configure.ac: Added AC_CHECK_SIZEOF macro.
* configure.ac: Remove RTEMS_BSP_BOOTCARD_OPTIONS.
* configure.ac: Rename BSP_BOOTCARD_OPTIONS to
RTEMS_BSP_BOOTCARD_OPTIONS. Add RTEMS_BSP_CLEANUP_OPTIONS so all BSPs
have the same options.
* configure.ac: Make letting boot_card() handle work area allocation
mandatory. Rename RTEMS_BSP_BOOTCARD_HANDLES_RAM_ALLOCATION to
* Makefile.am, configure.ac, include/bsp.h, startup/bspstart.c: Use
PowerPC level shared bsp_get_work_area() implementation.
* configure.ac: Remove explicit ampolish3 support (now in
RTEMS_BSP_CONFIGURE).
* configure.ac: Add ampolish3 support.
* Makefile.am: Add preinstall.am.
* configure.ac: Remove argument from RTEMS_PPC_EXCEPTIONS.
* Makefile.am: Merge-in wrapup/Makefile.am.
* wrapup/Makefile.am: Remove.
* README, configure.ac, GT64260/Makefile.am, include/bsp.h,
irq/Makefile.am, irq/irq.c, irq/irq.h, irq/irq_init.c,
network/GT64260ethreg.h, pci/pci.c, startup/bspstart.c: CVS Id string
and license corrected.
* GT64260/Makefile.in, clock/Makefile.in, console/Makefile.in,
include/Makefile.am, include/Makefile.in, irq/Makefile.in,
network/Makefile.in, pci/Makefile.in, start/Makefile.in,
startup/Makefile.in, vectors/Makefile.in, vme/Makefile.in,
wrapup/Makefile.in: Removed.
