Instead of SPRG0 (= special purpose register 272) use the new global
symbol _PPC_INTERRUPT_DISABLE_MASK to store the interrupt disable mask.
The benefit is that it is now possible to disable interrupts without
further run-time initialization in boot_card().
At least on Freescale e500 cores this leads also to a faster execution
since the mfmsr and mfspr instruction require four cycles to complete.
The instructions to load the mask value can execute while the mfmsr is
in progress.
sequence must be executed in MOTLoad before booting RTEMS to remove its network interface interrupt handlers, lest memory corruption occur
Add reserved system events RTEMS_EVENT_SYSTEM_NETWORK_SBWAIT and
RTEMS_EVENT_SYSTEM_NETWORK_SOSLEEP.
Add and use rtems_bsdnet_event_send().
Conflicts:
for details.
* start/start.S: Tag TOS with a NULL pointer
(help terminate when walking the stack).
* Makefile.am: Remove reference to wrapup directory.
* configure.ac: Use standard cache BSP options.
PR1797/bsps: Applied cleaned-up version of Kate's patch.
CONFIGURE_MALLOC_BSP_SUPPORTS_SBRK is now a 'bspopts.h'
setting and as such configurable.
* network/tsec.c:
* beatnik/include/bsp.h, beatnik/irq/irq.h, beatnik/pci/gt_pci_init.c,
ep1a/console/polled_io.c, ep1a/irq/openpic_xxx_irq.c,
gen5200/include/irq.h, gen5200/irq/irq.c, gen5200/startup/bspstart.c,
haleakala/irq/irq.c, mbx8xx/irq/irq.c, mbx8xx/irq/irq.h,
motorola_powerpc/include/bsp.h, mpc8260ads/irq/irq.c,
mpc8260ads/irq/irq.h, mvme3100/include/bsp.h, mvme3100/irq/irq.h,
mvme3100/start/start.S, mvme5500/include/bsp.h, mvme5500/irq/irq.h,
psim/include/bsp.h, psim/include/coverhd.h, psim/irq/irq.h,
psim/shmsupp/addrconv.c, psim/shmsupp/getcfg.c,
psim/startup/linkcmds, psim/tools/psim-gdb-top.in,
psim/tools/psim-top.in, psim/tools/runtest-top.in, qemuppc/irq/irq.h,
score603e/irq/irq.c, shared/bootloader/bootldr.h,
shared/bootloader/em86.c, shared/bootloader/em86real.S,
shared/bootloader/exception.S, shared/bootloader/head.S,
shared/bootloader/lib.c, shared/bootloader/misc.c,
shared/bootloader/mm.c, shared/bootloader/pci.c,
shared/console/console.c, shared/console/consoleIo.h,
shared/console/inch.c, shared/console/keyboard.h,
shared/console/polled_io.c, shared/irq/i8259.c, shared/irq/irq.h,
shared/irq/openpic_i8259_irq.c, shared/motorola/motorola.c,
shared/motorola/motorola.h, shared/openpic/openpic.c,
shared/openpic/openpic.h, shared/pci/pci.c,
shared/residual/residual.c, shared/start/start.S, ss555/irq/irq.h:
Fix typo where license said found in found in.
* configure.ac: BSP supports bsp_reset() method.
PR 1685/bsps
* startup/bspstart.c: Add BSP_poll_char.
* configure.ac: Remove AC_CHECK_SIZEOF([void *]).
* configure.ac: Added AC_CHECK_SIZEOF macro.
* network/tsec.c: Added code to restart halted DMA
after a TX error (from error-isr). Added statistics
counters for restarts and DMA bus errors.
* make/custom/mvme3100.cfg: Remove RTEMS_BSP_FAMILY.
* startup/bspstart.c, startup/misc.c:
Fixed compiler warnings by adding prototypes to function
declarations and moving extern declarations to global scope.
* start/start.S, startup/bspstart.c:
let 'save_boot_params()' return a pointer to the commandline
saved by the BSP and pass this pointer on to 'boot_card()'.
* network/tsec.c: fixed compiler warnings.
* network/tsec.c: rtems 4.10 no longer allows simple binary
semaphores to have priority inheritance attribute; use ordinary
binary semaphore instead.
*network/if_tsec_pub.h, network/tsec.c: Enhanced low-level
API allowing the user to selectively enable/disable/acknowledge
interrupts and to install their own ISR (rather than having
the driver posting an event to a single task).
* make/custom/mvme3100.cfg: New (relocated from /make/custom).
PR 1451/bsps
* network/tsec.c: Fix mbuf leak when watchdog expires. The
re-initialization algorithm failed to release mbuf chains
held in the TX ring.
Also, during initialization the initial link status is determined
and IFF_OACTIVE set if no active link was detected.
* configure.ac: Remove RTEMS_BSP_BOOTCARD_OPTIONS.
* include/bsp.h: Eliminate BSPs defining NUMBER_OF_TERMIOS_PORTS.
Should be automatically handled by confdefs.h or the application.
* network/tsec.c, network/if_tsec_pub.h:
Fixed bugs in multicast support; added reference-count
for hash-table entries which allows for the implementation
of a 'deletion' routine.
NOTE: mcast support largely untested.
* configure.ac: Rename BSP_BOOTCARD_OPTIONS to
RTEMS_BSP_BOOTCARD_OPTIONS. Add RTEMS_BSP_CLEANUP_OPTIONS so all BSPs
have the same options.
implemented multicast support.
