2017-02-15 | bsps/powerpc: Fix warnings | Sebastian Huber | 1 | -1/+1 | |
2012-05-11 | Remove All CVS Id Strings Possible Using a Script | Joel Sherrill | 1 | -2/+0 | |
Script does what is expected and tries to do it as smartly as possible. + remove occurrences of two blank comment lines next to each other after Id string line removed. + remove entire comment blocks which only exited to contain CVS Ids + If the processing left a blank line at the top of a file, it was removed. | |||||
2009-11-30 | Whitespace removal. | Ralf Corsepius | 1 | -10/+10 | |
2009-03-05 | 2009-03-05 Till Straumann <strauman@slac.stanford.edu> | Till Straumann | 1 | -1/+1 | |
* startup/misc.c, flash/flashcfg.c, irq/irq_init.c, pci/detect_host_bridge.c: changed function arguments to silence compiler warnings. | |||||
2008-08-20 | Add missing prototypes. | Ralf Corsepius | 1 | -2/+2 | |
