path: root/c/src/lib/libbsp/powerpc/mvme2307/Makefile.in (follow)
* Patch rtems-rc-19991117-9.diff from Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill1999-11-221-3/+3
| | | | | to convert the libc directory to automake and "dozens of small fixes for Makefile.ins/configure.ins below c/src/lib."
* Patch rtems-rc-19991117-4.diff from Ralf Corsepius <corsepiu@faw.uni-ulm.de>:Joel Sherrill1999-11-221-1/+1
* Removed shmsupp directory as it is not really implemented.Joel Sherrill1999-11-011-6/+1
* Minor corrections to get mvme2307 to compile.Joel Sherrill1999-10-051-2/+2
* Motorola MVME2307 BSP submitted by Jay Kulpinski <jskulpin@eng01.gdds.com>.Joel Sherrill1999-10-041-0/+41
No modifications made.
