* | 2006-12-02 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2006-12-02 | 2 | -1/+5 |
| | | | | * configure.ac: New BUG-REPORT address. | ||||
* | 2006-11-15 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2006-11-15 | 2 | -1/+6 |
| | | | | | * Makefile.am: Merge c_rtems_main() into boot_card(). This eliminated a file and simplified initialization. | ||||
* | 2006-10-17 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2006-10-17 | 2 | -1/+5 |
| | | | | * Makefile.am: Remove superfluous -DASM. | ||||
* | 2006-10-17 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2006-10-17 | 2 | -2/+6 |
| | | | | * configure.ac: Require autoconf-2.60. Require automake-1.10. | ||||
* | 2006-08-09 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2006-08-09 | 2 | -1/+47 |
| | | | | * startup/linkcmds: Clean up a bit after adding missing .rela sections. | ||||
* | Remove eof include file | Ralf Corsepius | 2006-03-17 | 2 | -2/+0 |
* | 2006-03-08 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2006-03-08 | 2 | -1/+6 |
| | | | | * startup/linkcmds: Add .gnu.linkonce.b.* section. | ||||
* | 2006-02-08 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2006-02-08 | 2 | -6/+9 |
| | | | | * startup/linkcmds: Add sections required by newer gcc versions. | ||||
* | Regenerate. | Ralf Corsepius | 2006-01-14 | 1 | -1/+1 |
* | Regenerate. | Ralf Corsepius | 2006-01-12 | 1 | -0/+4 |
* | Remove all-local:. | Ralf Corsepius | 2006-01-12 | 1 | -2/+0 |
* | Regenerate. | Ralf Corsepius | 2006-01-12 | 1 | -1/+1 |
* | Cleanup. | Ralf Corsepius | 2006-01-12 | 1 | -2/+0 |
* | 2006-01-11 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2006-01-11 | 2 | -4/+5 |
| | | | | | * configure.ac: Remove explicit ampolish3 support (now in RTEMS_BSP_CONFIGURE). | ||||
* | 2006-01-10 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2006-01-10 | 3 | -58/+11 |
| | | | | | * configure.ac: Add ampolish3 support. * Makefile.am: Add preinstall.am. | ||||
* | New. | Ralf Corsepius | 2006-01-10 | 1 | -0/+67 |
* | 2006-01-09 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2006-01-09 | 2 | -1/+4 |
| | | | | * Makefile.am: Don't include subdirs.am. | ||||
* | 2005-10-06 Till Straumann <strauman@slac.stanford.edu> | Joel Sherrill | 2005-10-06 | 2 | -4/+33 |
| | | | | | | | | | PR 833/bsps * irq/irq_asm.S: Currently, all (new exception) BSPs explicitely enable the FPU across the user ISR but DONT save/restore the FPU context. Any use of the FPU fron the user handler (e.g., due to GCC optimizations) result in corruption. The fix results in an exception in such cases (user ISR must explicitely save/enable/restore FPU). | ||||
* | 2005-09-19 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2005-09-19 | 1 | -0/+5 |
| | | | | | * network/if_hdlcsubr.c, network/network.c: Include <errno.h> instead of <sys/errno.h>. | ||||
* | Include <errno.h> instead of <sys/errno.h>. | Ralf Corsepius | 2005-09-19 | 2 | -2/+2 |
* | 2005-05-26 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2005-05-26 | 2 | -0/+7 |
| | | | | | | PR 799/bsps * include/bsp.h: Add include of bsp/vectors.h so rdbg.h can be compiled. | ||||
* | 2005-05-26 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2005-05-26 | 2 | -2/+6 |
| | | | | * include/bsp.h: New header guard. | ||||
* | 2005-05-17 Jennifer Averett <jennifer.averett@oarcorp.com> | Jennifer Averett | 2005-05-17 | 3 | -236/+82 |
| | | | | * irq/irq.c, irq/irq.h: Modified to use rtems/irq.h. | ||||
* | 2005-05-10 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2005-05-10 | 2 | -0/+5 |
| | | | | * Makefile.am: Add -D__BSD_VISIBLE to network_CPPFLAGS. | ||||
* | 2005-04-15 Jennifer Averett <jennifer.averett@oarcorp.com> | Jennifer Averett | 2005-04-15 | 6 | -6/+20 |
| | | | | | | | PR 779/bsp * clock/p_clock.c, irq/irq.c, irq/irq.h, irq/irq_init.c, network/network.c: add parameter to new exception interrupt handlers in powerpc bsps | ||||
* | 2005-02-17 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2005-02-17 | 2 | -1/+9 |
| | | | | | | * startup/bspstart.c: include <rtems/powerpc/powerpc.h>. Use PPC_MINIMUM_STACK_FRAME_SIZE instead of CPU_MINIMUM_STACK_FRAME_SIZE. | ||||
* | 2005-02-16 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2005-02-16 | 2 | -1/+5 |
| | | | | * configure.ac: Remove argument from RTEMS_PPC_EXCEPTIONS. | ||||
* | Remove. | Ralf Corsepius | 2005-02-12 | 1 | -2/+0 |
* | 2005-02-11 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2005-02-12 | 4 | -31/+23 |
| | | | | | | * Makefile.am: Merge-in wrapup/Makefile.am. * wrapup/Makefile.am: Remove. * configure.ac: Reflect changes above. | ||||
* | Cosmetics. | Ralf Corsepius | 2005-01-28 | 1 | -2/+1 |
* | 2005-01-07 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2005-01-07 | 2 | -6/+10 |
| | | | | * Makefile.am: Eliminate CFLAGS_OPTIMIZE_V. | ||||
* | 2005-01-04 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2005-01-04 | 2 | -1/+5 |
| | | | | * startup/linkcmds: Remove warnings. | ||||
* | 2005-01-02 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2005-01-03 | 3 | -94/+33 |
| | | | | * Makefile.am, wrapup/Makefile.am: Remove build-variant support. | ||||
* | 2004-09-27 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2004-09-27 | 2 | -0/+7 |
| | | | | | PR 680/bsps * network/if_hdlcsubr.c: Add missing #include <rtems/rtems_bsdnet.h>. | ||||
* | Fix typo in previous change. | Ralf Corsepius | 2004-09-24 | 1 | -1/+1 |
* | 2004-09-24 Ralf Corsepius <ralf_corsepius@rtems.org> | Ralf Corsepius | 2004-09-24 | 2 | -1/+5 |
| | | | | * configure.ac: Require automake > 1.9. | ||||
* | 2004-07-25 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2004-07-25 | 2 | -0/+5 |
| | | | | * network/network.c: Add include of <sys/errno.h>. | ||||
* | 2004-04-23 Ralf Corsepius <ralf_corsepius@rtems.org> | Ralf Corsepius | 2004-04-23 | 3 | -3/+14 |
| | | | | | | PR 610/bsps * Makefile.am: Add include/tm27.h, Cosmetics. * include/tm27.h: Final cosmetics. | ||||
* | 2004-04-22 Ralf Corsepius <ralf_corsepius@rtems.org> | Ralf Corsepius | 2004-04-23 | 3 | -24/+47 |
| | | | | | * include/bsp.h: Split out tmtest27 support. * include/tm27.h: New. | ||||
* | 2004-04-21 Ralf Corsepius <ralf_corsepius@rtems.org> | Ralf Corsepius | 2004-04-21 | 2 | -10/+5 |
| | | | | | PR 613/bsps * include/bsp.h: Remove MAX_LONG_TEST_DURATION. | ||||
* | 2004-04-21 Ralf Corsepius <ralf_corsepius@rtems.org> | Ralf Corsepius | 2004-04-21 | 2 | -1/+5 |
| | | | | | PR 614/bsps * include/bsp.h: Remove MAX_SHORT_TEST_DURATION (Unused). | ||||
* | Remove duplicate white lines. | Ralf Corsepius | 2004-04-21 | 15 | -128/+0 |
* | Remove stray white spaces. | Ralf Corsepius | 2004-04-21 | 15 | -204/+204 |
* | Remove stray white spaces. | Ralf Corsepius | 2004-04-15 | 6 | -8/+0 |
* | * irq/irq_asm.S: Include <rtems/asm.h> instead of <asm.h>. | Ralf Corsepius | 2004-04-02 | 2 | -1/+5 |
* | 2004-04-01 Ralf Corsepius <ralf_corsepius@rtems.org> | Ralf Corsepius | 2004-04-01 | 4 | -4/+11 |
| | | | | | | | * start/start.S: Include <rtems/asm.h> instead of <asm.h>. * vectors/vectors.S: Include <rtems/asm.h> instead of <asm.h>. * include/bsp.h: Include <rtems/clockdrv.h> instead of <clockdrv.h>. * include/bsp.h: Include <rtems/console.h> instead of <console.h>. | ||||
* | 2004-03-31 Ralf Corsepius <ralf_corsepius@rtems.org> | Ralf Corsepius | 2004-03-31 | 6 | -18/+23 |
| | | | | | * console/console.c, include/bsp.h, irq/irq.c, network/network.c, startup/bspstart.c: Convert to using c99 fixed size types. | ||||
* | Remove refs to Makefile*. | Ralf Corsepius | 2004-03-09 | 1 | -2/+0 |
* | 2004-03-03 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2004-03-03 | 2 | -1/+5 |
| | | | | * irq/irq.h: Correct typo. | ||||
* | 2004-02-19 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2004-02-19 | 2 | -2/+35 |
| | | | | | * Makefile.am: Reflect changes to bsp.am. Preinstall dist_project_lib*. |
