* network/if_hdlcsubr.c: Use memcopy instead of bcmp,
Use memcmp instead of bcmp.
PR 288/rtems
* startup/bspstart.c: _ISR_Nest_level is now properly maintained.
* startup/linkcmds: Add FreeBSD SYSCTL() sections for networking.
* irq/Makefile.am: Don't include @RTEMS_BSP@.cfg.
Remove SORDID_HACK. Eliminate *_O_FILES.
* vectors/Makefile.am: Don't include @RTEMS_BSP@.cfg.
* irq/irq.c: Removed warnings.
* console/console.c, irq/irq.c, network/if_hdlcsubr.c,
network/if_hdlcsubr.h, network/network.c, vectors/vectors_init.c:
Removed warnings.
* irq/irq.c, irq/irq_asm.S, startup/bspstart.c: Fixed typos and
removed warnings.
* irq/irq.c, irq/irq_asm.S, irq/irq_init.c: Per PR288, add support
for _ISR_Nest_level.
* .cvsignore: Reformat.
Add autom4te*cache.
Remove autom4te.cache.
* irq/Makefile.am: Use .$(OBJEXT) instead of .o.
* network/Makefile.am: Use .$(OBJEXT) instead of .o.
* startup/linkcmds: In support of gcc 3.1, added one of more
of the sections .jcr, .rodata*, .data.*, .gnu.linkonce.s2.*,
.gnu.linkonce.sb2.*, and .gnu.linkonce.s.*. Spacing corrections
and direction of segments to memory regions may also have been
addressed. This was a sweep across all BSPs.
* irq/irq.c: Reflect changes to <rtems/score/cpu.h>.
* irq/irq_asm.S: Ditto.
* network/network.c: Include <rtems/bspIo.h>.
* start/start.S: Include <asm.h> instead of "asm.h".
* vectors/vectors.S: Reflect changes to <rtems/score/cpu.h>.
* startup/bspstart.c: Include <libcpu/cpuIdent.h>, <rtems/bspIo.h>.
* configure.ac: Add BSPOPTS_*(DISPATCH_HANDLER_STAT).
* vectors/Makefile.am: Remove AUTOMAKE_OPTIONS.
* configure.ac: Add RTEMS_CHECK_NETWORKING.
* clock/p_clock.c: Include rtems/bspIo.h instead of bspIo.h.
* console/console.c: Include rtems/bspIo.h instead of bspIo.h.
* irq/irq_init.c: Include rtems/bspIo.h instead of bspIo.h.
* configure.ac: Add RTEMS_BSPOPTS_*(DATA_CACHE_ENABLE),
RTEMS_BSPOPTS_*(INSTRUCTION_CACHE_ENABLE).
* Makefile.am: Add @exceptions@ to SUBDIRS.
* configure.ac: Apply RTEMS_BSPOPTS_*(*) to merge-in settings from
make/custom/mpc8260ads.cfg, add RTEMS_PPC_EXCEPTIONS([new]).
* include/Makefile.am: Convert PREINSTALL_FILES to
TMPINSTALL_FILES, include force-preinstall.am.
* wrapup/Makefile.am: Apply @exceptions@.
* .cvsignore: Add more entries.
* aclocal.m4: Removed. Should not have been in CVS.
* aclocal.m4: Regenerated.
* configure.ac, include/Makefile.am, irq/Makefile.am,
vectors/Makefile.am: Updated to autoconf 2.52.
* include/.cvsignore: Added newly generated files.
* include/bsp.h: Added include of bspopts.h.
* .cvsignore, configure.ac, configure.in, console/.cvsignore,
include/.cvsignore, network/.cvsignore, start/.cvsignore,
startup/.cvsignore, wrapup/.cvsignore: Added .cvsignore
files and other files missed in previous commit.
* mpc8260ads added as new BSP. tm27 reported not to run
at this time.
* ChangeLog, Makefile.am, README, aclocal.m4, bsp_specs,
clock/.cvsignore, clock/Makefile.am, clock/p_clock.c, configure.in,
console/Makefile.am, console/console.c, include/Makefile.am,
include/bsp.h, include/coverhd.h, irq/.cvsignore, irq/Makefile.am,
irq/irq.c, irq/irq.h, irq/irq_asm.S, irq/irq_init.c,
network/Makefile.am, network/README, network/if_hdlcsubr.c,
network/if_hdlcsubr.h, network/network.c, start/Makefile.am,
start/start.S, startup/Makefile.am, startup/bspstart.c,
startup/cpuinit.c, startup/linkcmds, startup/setvec.c, times,
vectors/.cvsignore, vectors/Makefile.am, vectors/vectors.S,
vectors/vectors.h, vectors/vectors_init.c, wrapup/Makefile.am:
New files.
