* wrapup/Makefile.am: Convert to automake-building rules.
* Makefile.am: Merge-in clock/.cvsignore, console/.cvsignore,
irq/.cvsignore, network/.cvsignore, startup/.cvsignore,
vectors/.cvsignore. Use automake compilation rules.
* clock/.cvsignore, console/.cvsignore, irq/.cvsignore,
network/.cvsignore, startup/.cvsignore, vectors/.cvsignore: Remove.
* wrapup/Makefile: Reflect changes above.
* wrapup/Makefile.am: Reflect changes to
../support/*exception_processing/*.
* irq/Makefile.am: Add PREINSTALL_DIRS.
* vectors/Makefile.am: Add PREINSTALL_DIRS.
* wrapup/Makefile.am: Reflect changes to libcpu.
* wrapup/Makefile.am: Eliminate $(LIB).
Use noinst_DATA to trigger building libbsp.a.
* startup/linkcmds: Preparations for gcc-3.3.x.
* startup/Makefile.am: Remove S_FILES (Unused).
* vectors/Makefile.am: Cosmetics.
* irq/Makefile.am: Add preinstallation dirstamp support.
* network/Makefile.am: Cosmetics.
* vectors/Makefile.am: Add preinstallation dirstamp support.
* irq/Makefile.am: Remove all-local: $(ARCH).
irq/Makefile.am: Reflect having moved automake.
* irq/Makefile.am: Use .$(OBJEXT) instead of .o.
* network/Makefile.am: Use .$(OBJEXT) instead of .o.
* vectors/Makefile.am: Remove AUTOMAKE_OPTIONS.
* Makefile.am: Add @exceptions@ to SUBDIRS.
* configure.ac: Apply RTEMS_BSPOPTS_*(*) to merge-in settings from
make/custom/mpc8260ads.cfg, add RTEMS_PPC_EXCEPTIONS([new]).
* include/Makefile.am: Convert PREINSTALL_FILES to
TMPINSTALL_FILES, include force-preinstall.am.
* wrapup/Makefile.am: Apply @exceptions@.
* .cvsignore, configure.ac, configure.in, console/.cvsignore,
include/.cvsignore, network/.cvsignore, start/.cvsignore,
startup/.cvsignore, wrapup/.cvsignore: Added .cvsignore
files and other files missed in previous commit.
* mpc8260ads added as new BSP. tm27 reported not to run
at this time.
* ChangeLog, Makefile.am, README, aclocal.m4, bsp_specs,
clock/.cvsignore, clock/Makefile.am, clock/p_clock.c, configure.in,
console/Makefile.am, console/console.c, include/Makefile.am,
include/bsp.h, include/coverhd.h, irq/.cvsignore, irq/Makefile.am,
irq/irq.c, irq/irq.h, irq/irq_asm.S, irq/irq_init.c,
network/Makefile.am, network/README, network/if_hdlcsubr.c,
network/if_hdlcsubr.h, network/network.c, start/Makefile.am,
start/start.S, startup/Makefile.am, startup/bspstart.c,
startup/cpuinit.c, startup/linkcmds, startup/setvec.c, times,
vectors/.cvsignore, vectors/Makefile.am, vectors/vectors.S,
vectors/vectors.h, vectors/vectors_init.c, wrapup/Makefile.am:
New files.
