* Makefile.am: Merge-in wrapup/Makefile.am.
* wrapup/Makefile.am: Remove.
* Makefile.am, wrapup/Makefile.am: Remove build-variant support.
* wrapup/Makefile.am: Convert to automake-building rules.
* Makefile.am: Merge-in clock/.cvsignore, console/.cvsignore,
irq/.cvsignore, network/.cvsignore, startup/.cvsignore,
vectors/.cvsignore. Use automake compilation rules.
* clock/.cvsignore, console/.cvsignore, irq/.cvsignore,
network/.cvsignore, startup/.cvsignore, vectors/.cvsignore: Remove.
* wrapup/Makefile: Reflect changes above.
* wrapup/Makefile.am: Reflect changes to
../support/*exception_processing/*.
* irq/Makefile.am: Add PREINSTALL_DIRS.
* vectors/Makefile.am: Add PREINSTALL_DIRS.
* wrapup/Makefile.am: Reflect changes to libcpu.
* wrapup/Makefile.am: Eliminate $(LIB).
Use noinst_DATA to trigger building libbsp.a.
* startup/linkcmds: Preparations for gcc-3.3.x.
* startup/Makefile.am: Remove S_FILES (Unused).
* vectors/Makefile.am: Cosmetics.
* irq/Makefile.am: Add preinstallation dirstamp support.
* network/Makefile.am: Cosmetics.
* vectors/Makefile.am: Add preinstallation dirstamp support.
* irq/Makefile.am: Remove all-local: $(ARCH).
irq/Makefile.am: Reflect having moved automake.
* irq/Makefile.am: Use .$(OBJEXT) instead of .o.
* network/Makefile.am: Use .$(OBJEXT) instead of .o.
* vectors/Makefile.am: Remove AUTOMAKE_OPTIONS.
* Makefile.am: Add @exceptions@ to SUBDIRS.
* configure.ac: Apply RTEMS_BSPOPTS_*(*) to merge-in settings from
make/custom/mpc8260ads.cfg, add RTEMS_PPC_EXCEPTIONS([new]).
* include/Makefile.am: Convert PREINSTALL_FILES to
TMPINSTALL_FILES, include force-preinstall.am.
* wrapup/Makefile.am: Apply @exceptions@.
* mpc8260ads added as new BSP. tm27 reported not to run
at this time.
* ChangeLog, Makefile.am, README, aclocal.m4, bsp_specs,
clock/.cvsignore, clock/Makefile.am, clock/p_clock.c, configure.in,
console/Makefile.am, console/console.c, include/Makefile.am,
include/bsp.h, include/coverhd.h, irq/.cvsignore, irq/Makefile.am,
irq/irq.c, irq/irq.h, irq/irq_asm.S, irq/irq_init.c,
network/Makefile.am, network/README, network/if_hdlcsubr.c,
network/if_hdlcsubr.h, network/network.c, start/Makefile.am,
start/start.S, startup/Makefile.am, startup/bspstart.c,
startup/cpuinit.c, startup/linkcmds, startup/setvec.c, times,
vectors/.cvsignore, vectors/Makefile.am, vectors/vectors.S,
vectors/vectors.h, vectors/vectors_init.c, wrapup/Makefile.am:
New files.
* clock/.cvsignore, clock/Makefile.am, clock/p_clock.c,
include/8xx_immap.h, include/commproc.h, include/mbx.h,
irq/.cvsignore, irq/Makefile.am, irq/irq.c, irq/irq.h,
irq/irq_asm.S, irq/irq_init.c, vectors/.cvsignore,
vectors/Makefile.am, vectors/vectors.S, vectors/vectors.h,
vectors/vectors_init.c: New files.
* Makefile.am, configure.in, console/console.c,
include/Makefile.am, network/network.c, startup/Makefile.am,
startup/bspstart.c, startup/imbx8xx.c, startup/linkcmds,
startup/mmutlbtab.c, startup/start.S, wrapup/Makefile.am:
The modifications to this BSP reflect the conversion of the
mpc8xx CPU to the "new exception processing model."
* console/Makefile.am, network/Makefile.am, startup/Makefile.am,
from score/cpu to libcpu because the determination of which to use is
based on RTEMS_CPU_MODEL. Thus it can not be determined based solely on
multilib information.
responsibility to explicitly pick up the components they
require. This makes it easier to override default implmentations.
significant things:
and PowerPC
same code base.
converted to automake.
that converts the a29k to automake.
This patch contains
* An initial merger of the libcpu/a29k stuff you sent yesterday. AFAIS,
most code inside them seems to be empty stubs. One file even contains a
function called mips_*** which might indicate that this part might
contain mips code or the code the initial porter used as template for
porting. Unfortunately, I don't know anything about the a29k so I can't
comment on the details.
* A dummy bsp_specs to libbsp/29k/portsw
* An update to the automake files related to the a29k.
Note:
* This patch is completely untested, because I don't have a toolchain
for it.
* The files in libcpu/a29k include bsp.h => The libbsp vs. libcpu-issue
hits again.
that converts the libbsp/i386 subdirectory to full automake.
