* irq/Makefile.am: Remove all-local: $(ARCH).
irq/Makefile.am: Reflect having moved automake.
* irq/Makefile.am: Don't include @RTEMS_BSP@.cfg.
Remove SORDID_HACK. Eliminate *_O_FILES.
* vectors/Makefile.am: Don't include @RTEMS_BSP@.cfg.
* irq/Makefile.am: Use .$(OBJEXT) instead of .o.
* network/Makefile.am: Use .$(OBJEXT) instead of .o.
* irq/irq.c: Reflect changes to <rtems/score/cpu.h>.
* irq/irq_asm.S: Ditto.
* network/network.c: Include <rtems/bspIo.h>.
* start/start.S: Include <asm.h> instead of "asm.h".
* vectors/vectors.S: Reflect changes to <rtems/score/cpu.h>.
* vectors/Makefile.am: Remove AUTOMAKE_OPTIONS.
* .cvsignore, configure.ac, configure.in, console/.cvsignore,
include/.cvsignore, network/.cvsignore, start/.cvsignore,
startup/.cvsignore, wrapup/.cvsignore: Added .cvsignore
files and other files missed in previous commit.
* mpc8260ads added as new BSP. tm27 reported not to run
at this time.
* ChangeLog, Makefile.am, README, aclocal.m4, bsp_specs,
clock/.cvsignore, clock/Makefile.am, clock/p_clock.c, configure.in,
console/Makefile.am, console/console.c, include/Makefile.am,
include/bsp.h, include/coverhd.h, irq/.cvsignore, irq/Makefile.am,
irq/irq.c, irq/irq.h, irq/irq_asm.S, irq/irq_init.c,
network/Makefile.am, network/README, network/if_hdlcsubr.c,
network/if_hdlcsubr.h, network/network.c, start/Makefile.am,
start/start.S, startup/Makefile.am, startup/bspstart.c,
startup/cpuinit.c, startup/linkcmds, startup/setvec.c, times,
vectors/.cvsignore, vectors/Makefile.am, vectors/vectors.S,
vectors/vectors.h, vectors/vectors_init.c, wrapup/Makefile.am:
New files.
