* | 2003-12-02 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2003-12-02 | 1 | -1/+1 |
| | | | | | | | | | | | * clock/Makefile.am: Remove all-local: $(ARCH). * console/Makefile.am: Remove all-local: $(ARCH). * irq/Makefile.am: Remove all-local: $(ARCH). * network/Makefile.am: Remove all-local: $(ARCH). * start/Makefile.am: Remove all-local: $(ARCH). * startup/Makefile.am: Remove all-local: $(ARCH). * vectors/Makefile.am: Remove all-local: $(ARCH). * wrapup/Makefile.am: Remove all-local: $(ARCH). | ||||
* | 2003-08-16 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2003-08-16 | 1 | -3/+3 |
| | | | | | | | | | | | | | Makefile.am: Reflect having moved automake. clock/Makefile.am: Reflect having moved automake. console/Makefile.am: Reflect having moved automake. include/Makefile.am: Reflect having moved automake. irq/Makefile.am: Reflect having moved automake. network/Makefile.am: Reflect having moved automake. start/Makefile.am: Reflect having moved automake. startup/Makefile.am: Reflect having moved automake. vectors/Makefile.am: Reflect having moved automake. wrapup/Makefile.am: Reflect having moved automake. | ||||
* | 2002-12-17 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2002-12-17 | 1 | -1/+0 |
| | | | | | | | | | | | * clock/Makefile.am: Don't include @RTEMS_BSP@.cfg. * console/Makefile.am: Don't include @RTEMS_BSP@.cfg. * irq/Makefile.am: Don't include @RTEMS_BSP@.cfg. Remove SORDID_HACK. Eliminate *_O_FILES. * network/Makefile.am: Don't include @RTEMS_BSP@.cfg. * start/Makefile.am: Don't include @RTEMS_BSP@.cfg. * startup/Makefile.am: Don't include @RTEMS_BSP@.cfg. * vectors/Makefile.am: Don't include @RTEMS_BSP@.cfg. | ||||
* | 2002-08-11 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2002-08-11 | 1 | -1/+1 |
| | | | | | | | | | | | * clock/Makefile.am: Use .$(OBJEXT) instead of .o. * console/Makefile.am: Use .$(OBJEXT) instead of .o. * irq/Makefile.am: Use .$(OBJEXT) instead of .o. * network/Makefile.am: Use .$(OBJEXT) instead of .o. * start/Makefile.am: Use .$(OBJEXT) instead of .o. * startup/Makefile.am: Use .$(OBJEXT) instead of .o. * vectors/Makefile.am: Use .$(OBJEXT) instead of .o. * wrapup/Makefile.am: Use .$(OBJEXT) instead of .o. | ||||
* | 2002-03-27 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Joel Sherrill | 2002-03-28 | 1 | -1/+0 |
| | | | | | | | | | | | | | | | | * configure.ac: AC_INIT(package,_RTEMS_VERSION,_RTEMS_BUGS). AM_INIT_AUTOMAKE([no-define foreign 1.6]). * clock/Makefile.am: Remove AUTOMAKE_OPTIONS. * Makefile.am: Remove AUTOMAKE_OPTIONS. * console/Makefile.am: Remove AUTOMAKE_OPTIONS. * include/Makefile.am: Remove AUTOMAKE_OPTIONS. * irq/Makefile.am: Remove AUTOMAKE_OPTIONS. * network/Makefile.am: Remove AUTOMAKE_OPTIONS. * start/Makefile.am: Remove AUTOMAKE_OPTIONS. * startup/Makefile.am: Remove AUTOMAKE_OPTIONS. * vectors/Makefile.am: Remove AUTOMAKE_OPTIONS. * wrapup/Makefile.am: Remove AUTOMAKE_OPTIONS. | ||||
* | 01-10-22 Andy Dachs <a.dachs@sstl.co.uk> | Joel Sherrill | 2001-10-22 | 1 | -0/+33 |
* mpc8260ads added as new BSP. tm27 reported not to run at this time. * ChangeLog, Makefile.am, README, aclocal.m4, bsp_specs, clock/.cvsignore, clock/Makefile.am, clock/p_clock.c, configure.in, console/Makefile.am, console/console.c, include/Makefile.am, include/bsp.h, include/coverhd.h, irq/.cvsignore, irq/Makefile.am, irq/irq.c, irq/irq.h, irq/irq_asm.S, irq/irq_init.c, network/Makefile.am, network/README, network/if_hdlcsubr.c, network/if_hdlcsubr.h, network/network.c, start/Makefile.am, start/start.S, startup/Makefile.am, startup/bspstart.c, startup/cpuinit.c, startup/linkcmds, startup/setvec.c, times, vectors/.cvsignore, vectors/Makefile.am, vectors/vectors.S, vectors/vectors.h, vectors/vectors_init.c, wrapup/Makefile.am: New files. |
