* | 2010-06-29 Joel Sherrill <joel.sherrill@oarcorp.com> | Joel Sherrill | 2010-06-29 | 2 | -4/+4 |
| | | | | * configure.ac: Remove AC_CHECK_SIZEOF([void *]). | ||||
* | 2010-06-29 Joel Sherrill <Joel.Sherrill@OARcorp.com> | Jennifer Averett | 2010-06-29 | 2 | -0/+8 |
| | | | | * configure.ac: Added AC_CHECK_SIZEOF macro. | ||||
* | fix bug in mount table | Thomas Doerfler | 2010-06-03 | 2 | -2/+6 |
* | 2010-05-20 Sebastian Huber <sebastian.huber@embedded-brains.de> | Sebastian Huber | 2010-05-20 | 2 | -30/+34 |
| | | | | * network/smsc9218i.c: Removed superfluous macros. | ||||
* | 2010-05-10 Joel Sherrill <joel.sherrilL@OARcorp.com> | Joel Sherrill | 2010-05-10 | 2 | -0/+6 |
| | | | | * include/bsp.h: Add BSP_SMALL_MEMORY. | ||||
* | 2010-04-30 Sebastian Huber <sebastian.huber@embedded-brains.de> | Sebastian Huber | 2010-04-30 | 4 | -81/+5 |
| | | | | | | | | * libcpu/powerpc/mpc55xx/include/irq.h: Move defines from 'libbsp/powerpc/mpc55xxevb/include/irq-config.h'. * libbsp/powerpc/mpc55xxevb/include/irq-config.h: Removed file. * libbsp/powerpc/mpc55xxevb/Makefile.am, libbsp/powerpc/mpc55xxevb/preinstall.am: Reflect changes above. | ||||
* | renamed MPC55XX_CHIP_DERIVATE to MPC55XX_CHIP_TYPE | Thomas Doerfler | 2010-04-07 | 3 | -8/+13 |
* | fixed to support GW_LCFM | Thomas Doerfler | 2010-04-07 | 16 | -355/+534 |
* | fixed some warnings | Thomas Doerfler | 2010-03-27 | 3 | -4/+11 |
* | removed warnings | Thomas Doerfler | 2010-03-27 | 3 | -3/+21 |
* | add support for mpc551x based GW_LCFM system | Thomas Doerfler | 2010-03-25 | 8 | -59/+325 |
* | Whitespace removal. | Ralf Corsepius | 2009-11-30 | 7 | -85/+85 |
* | Update for exception support changes. | Thomas Doerfler | 2009-10-23 | 3 | -9/+20 |
* | interrupt handler type change | Thomas Doerfler | 2009-10-21 | 4 | -24/+7 |
* | 2009-10-21 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2009-10-21 | 2 | -2/+4 |
| | | | | * make/custom/mpc55xx.cfg: Remove RTEMS_BSP_FAMILY. | ||||
* | 2009-10-20 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2009-10-20 | 2 | -1/+5 |
| | | | | * configure.ac: Don't add -ansi -fasm to CFLAGS. | ||||
* | 2009-10-15 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2009-10-15 | 3 | -0/+37 |
| | | | | | * make/custom/mpc5566evb.cfg: New (relocated from /make/custom). * make/custom/mpc55xx.cfg: New (relocated from /make/custom). | ||||
* | 2009-09-15 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2009-09-15 | 2 | -2/+5 |
| | | | | * configure.ac: Remove RTEMS_BSP_BOOTCARD_OPTIONS. | ||||
* | 2009-09-09 Joel Sherrill <joel.sherrill@oarcorp.com> | Joel Sherrill | 2009-09-10 | 3 | -42/+7 |
| | | | | | | PR 1435/bsps * Makefile.am: Use shared implementation of bsp_idle_thread(). * startup/bspidle.c: Removed. | ||||
* | 2009-08-26 Joel Sherrill <joel.sherrill@oarcorp.com> | Joel Sherrill | 2009-08-26 | 4 | -21/+49 |
| | | | | | | * Makefile.am, startup/bspstart.c: Rename BSP specific idle thread to bsp_idle_thread and split into its own file. * startup/bspidle.c: New file. | ||||
* | Update for MPC55XX changes | Thomas Doerfler | 2009-07-21 | 12 | -136/+2807 |
* | 2009-07-16 Joel Sherrill <joel.sherrill@oarcorp.com> | Joel Sherrill | 2009-07-16 | 2 | -1/+8 |
| | | | | | | * configure.ac: Rename BSP_BOOTCARD_OPTIONS to RTEMS_BSP_BOOTCARD_OPTIONS. Add RTEMS_BSP_CLEANUP_OPTIONS so all BSPs have the same options. | ||||
* | 2009-05-08 Joel Sherrill <joel.sherrill@oarcorp.com> | Joel Sherrill | 2009-05-08 | 2 | -5/+11 |
| | | | | | | * startup/bspgetworkarea.c: Switch from ssize_t to uintptr_t for bsp_get_work_area() since the work area is larger than a single allocatable object. | ||||
* | 2009-04-28 Chris Johns <chrisj@rtems.org> | Chris Johns | 2009-04-28 | 2 | -3/+10 |
| | | | | * startup/start.S: Update for boot_card command line change. | ||||
* | 2009-02-12 Joel Sherrill <joel.sherrill@oarcorp.com> | Joel Sherrill | 2009-02-12 | 2 | -1/+6 |
| | | | | | * startup/bspstart.c: Change prototype of IDLE thread to consistently return void * and take a uintptr_t argument. | ||||
* | 2009-02-11 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2009-02-11 | 2 | -0/+6 |
| | | | | | * startup/sd-card-init.c: Comment out fields having dropped out from sd_card_driver_entry. | ||||
* | 2009-02-11 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2009-02-11 | 2 | -0/+9 |
| | | | | | * tests/tests.c: Comment out fields having dropped out from sd_card_driver_entry. | ||||
* | 2008-12-05 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2008-12-05 | 2 | -4/+6 |
| | | | | * bsp_specs: Remove start_g.o, remove -e start. | ||||
* | 2008-12-04 Joel Sherrill <joel.sherrill@oarcorp.com> | Joel Sherrill | 2008-12-04 | 2 | -4/+11 |
| | | | | | | * bsp_specs: Move -e start from *link to *startfile to avoid warning for undefined entry symbol when linking relocatables with binutils 2.19. | ||||
* | Update for status-checks.h changes. | Thomas Doerfler | 2008-10-10 | 4 | -90/+95 |
* | 2008-10-02 Joel Sherrill <joel.sherrill@OARcorp.com> | Joel Sherrill | 2008-10-02 | 4 | -34/+7 |
| | | | | | * Makefile.am, preinstall.am: Use shared tm27.h stub. * include/tm27.h: Removed. | ||||
* | 2008-10-02 Joel Sherrill <joel.sherrill@oarcorp.com> | Joel Sherrill | 2008-10-02 | 2 | -3/+9 |
| | | | | | | * startup/bspgetworkarea.c: Change size_t to ssize_t on bsp_get_work_area(). On 16-bit architectures, size_t can be 16-bits which would limit the work area to 64K. | ||||
* | 2008-09-30 Joel Sherrill <joel.sherrill@oarcorp.com> | Joel Sherrill | 2008-09-30 | 4 | -1/+51 |
| | | | | | * Makefile.am, preinstall.am: Now links all tests. * include/tm27.h: New file. | ||||
* | 2008-09-29 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2008-09-29 | 2 | -9/+9 |
| | | | | | * Makefile.am: Eliminate bsp.am. Build startup files as side-effect of building libbspstart.a, using automake-rules. | ||||
* | 2008-09-29 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2008-09-29 | 2 | -6/+13 |
| | | | | * Makefile.am: Eliminate *_SOURCES. | ||||
* | 2008-09-29 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2008-09-29 | 2 | -1/+7 |
| | | | | | * Makefile.am: Move noinst_LIBRARIES = libbsp.a before its components. | ||||
* | 2008-09-26 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2008-09-26 | 3 | -6/+16 |
| | | | | * Makefile.am: Cleanup ../../shared/include/bootcard.h handling. | ||||
* | 2008-09-25 Joel Sherrill <joel.sherrill@oarcorp.com> | Joel Sherrill | 2008-09-25 | 2 | -5/+4 |
| | | | | * preinstall.am: Regenerated. | ||||
* | 2008-09-24 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2008-09-24 | 2 | -13/+15 |
| | | | | * Makefile.am: Eliminates libcpudir. | ||||
* | 2008-09-24 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2008-09-24 | 2 | -3/+6 |
| | | | | * Makefile.am: Cosmetics. | ||||
* | 2008-09-23 Joel Sherrill <joel.sherrill@oarcorp.com> | Joel Sherrill | 2008-09-23 | 2 | -1/+7 |
| | | | | | | * configure.ac: Make letting boot_card() handle work area allocation mandatory. Rename RTEMS_BSP_BOOTCARD_HANDLES_RAM_ALLOCATION to BSP_BOOTCARD_OPTIONS. | ||||
* | 2008-09-16 Joel Sherrill <joel.sherrill@oarcorp.com> | Joel Sherrill | 2008-09-16 | 4 | -17/+65 |
| | | | | | | | | * Makefile.am, startup/bspstart.c: Add use of bsp_get_work_area() in its own file and rely on BSP Framework to perform more initialization. Remove unnecessary includes of rtems/libio.h and rtems/libcsupport.h. * startup/bspgetworkarea.c: New file. | ||||
* | 2008-09-10 Joel Sherrill <joel.sherrill@oarcorp.com> | Joel Sherrill | 2008-09-10 | 3 | -27/+8 |
| | | | | | | | * Makefile.am: Review of all bsp_cleanup() implementations. In this phase, all prototypes were removed from bsp.h and empty implementations were removed and made to use the shared stub. * startup/bspclean.c: Removed. | ||||
* | 2008-08-30 Joel Sherrill <joel.sherrill@OARcorp.com> | Joel Sherrill | 2008-08-30 | 3 | -8/+5 |
| | | | | * Makefile.am, startup/bspstart.c: Use default bsp_pretasking_hook(). | ||||
* | 2008-08-20 Sebastian Huber <sebastian.huber@embedded-brains.de> | Joel Sherrill | 2008-08-20 | 7 | -26/+71 |
| | | | | | | | * include/mpc55xxevb.h, network/network.c, startup/sd-card-init.c, tests/tests.c: Added copyright information. Added missing prototypes. Fixed integer conversion warning. * startup/bspclean.c: Include bootcard.h. | ||||
* | 2008-08-20 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2008-08-20 | 1 | -0/+5 |
| | | | | | * startup/bspclean.c, startup/sd-card-init.c, tests/tests.c: Add missing prototypes. | ||||
* | Add missing prototypes. | Ralf Corsepius | 2008-08-20 | 3 | -5/+5 |
* | 2008-08-01 Sebastian Huber <sebastian.huber@embedded-brains.de> | Joel Sherrill | 2008-08-05 | 2 | -5/+10 |
| | | | | * startup/start.S: Clear environment pointer for bootcard. | ||||
* | 2008-07-31 Joel Sherrill <joel.sherrill@OARcorp.com> | Joel Sherrill | 2008-07-31 | 2 | -48/+39 |
| | | | | * Makefile.am: Do not build .rel files. Reduces code bloat. | ||||
* | 2008-07-31 Joel Sherrill <joel.sherrill@OARcorp.com> | Joel Sherrill | 2008-07-31 | 2 | -79/+87 |
| | | | | * tests/tests.c: Remove C++ style comments. |
