- A typo prevents if_smc.c from being built when configured;
- The argument passed to the interrupt handler was incorrect and the
addition of support for RTEMS_INTERRUPT_SHARED exposed it;
- A "#ifdef DEBUG" is supposed to be "#if DEBUG" since 0 is supposed to
make it quiet.
Conflicts:
Remove MPC55XX_ESCI_CONSOLE_MINOR.
Replace the "NIRVANA" region with the more verbose "UNEXPECTED_SECTIONS"
region. Move the region definition into the "linkcmds.base" files.
for details.
Add internal SRAM sections with cache enabled to early MMU settings.
The internal SRAM initialization will use the early MMU settings. This
allows applications to use cache inhibited areas in the internal SRAM.
Add defines MPC55XX_HAS_SIU and MPC55XX_HAS_SIU_LITE.
Rework of the start sequence to reduce the amount assembler code and to
support configuration tables which may be provided by the application.
* make/custom/mpc5566evb_spe.cfg, make/custom/mpc5674fevb_spe.cfg,
startup/linkcmds.mpc5566evb_spe, startup/linkcmds.mpc5674fevb_spe,
startup/reset.c: New files.
* Makefile.am, preinstall.am: Reflect changes above.
* startup/early-init.c: Added missing section attribute.
* configure.ac, network/smsc9218i.c: New BSP options
SMSC9218I_EDMA_RX_CHANNEL and SMSC9218I_EDMA_TX_CHANNEL. Enable reset
at cleanup.
* startup/bspgetworkarea.c, startup/linkcmds.base: Removed files.
* include/mpc55xx-config.h, make/custom/mpc5674fevb.cfg,
startup/early-init.c, startup/ebi-cal-cs-config.c,
startup/ebi-cs-config.c, startup/exc-vector-base.S,
startup/fmpll-syncr-vals.c, startup/linkcmds.mpc5674fevb,
startup/mmu-config.c, startup/siu-pcr-config.c: New files.
* startup/linkcmds.gwlcfm, startup/linkcmds.mpc5566evb,
startup/linkcmds.phycore_mpc5554: Use linker command base file.
* configure.ac: Support MPC5674F. Changed eSCI options.
* clock/clock-config.c: Support MPC5674F.
* i2c/i2c_init.c, network/smsc9218i.c, startup/sd-card-init.c: Update
due to API changes.
* include/bsp.h: Define BSP_INTERRUPT_STACK_AT_WORK_AREA_BEGIN.
* network/if_smc.c: Use HAS_SMC91111.
* startup/start.S, startup/bspstart.c: Moved low-level initialization
into new files. Overall cleanup.
* make/custom/phycore_mpc5554.cfg, startup/linkcmds.phycore_mpc5554,
network/if_smc.c: New files.
* configure.ac: Add support for the Phytec PhyCORE MPC5554. Includes:
- HAS_SMC91111 to indicate a BSP has that neworking.
- SMC91111_ENADDR_IS_SETUP so that it skips code to set up the MAC
address.
- MPC55XX_CLOCK_EMIOS_CHANNEL to permit one to set which eMIOS
channel to use for the clock.
- MPC55XX_BOOTFLAGS: Skips two words above the RCHW in the startup
for use in skpping over the MMU setup. Required for debugging via a
cheap emulator where code is loaded into RAM and then mapped in as
flash.
- BOARD_PHYCORE_MPC5554 If defined, use custom settings for the
Phytec PhyCORE MPC5554 SOM.
* clock/clock-config.c: Modify so that the EMIOS channel used for the
clock can be selected at configuration time. For MPC5544 only:
- Conditionally skip access to a register that faults if accessed on
the MPC5554
- Do not set the control register mode as was done for GW_LCFM
support, it breaks interrupts.
* make/custom/mpc55xx.inc: Make it possible to override the soft-float
to set the type of floating point BSP will use.
* startup/start.S: Add support for the "boot flags", two long-words
that I manipulate with the debugger to skip over MMU setup. Use an
external for the start of external SRAM instead of the hardwired
number 0x20000000. Disable write access to the internal flash.
* include/bsp.h: Define BSP_FEATURE_IRQ_EXTENSION.
* network/smsc9218i.c: Optimizations.
* Makefile.am: Added custom memcpy().
* startup/bspstart.c: Install standard alignment handler.
* configure.ac, startup/start.S: Use standard cache BSP options.
