* | score: Fix simple timecounter support | Sebastian Huber | 2016-01-27 | 1 | -14/+20 |
| | | | | Close #2502. | ||||
* | bsp/mpc55xxevb: Fix configure script | Sebastian Huber | 2015-06-26 | 1 | -2/+1 |
| | | | | | | This was the only configure.ac file with bspopts.h present in AC_CONFIG_FILES(). This somehow prevented the generation of this file leading to build errors for this BSP. | ||||
* | mpc55xxevb/clock/clock-config.c: Remove unused variable warning | Joel Sherrill | 2015-05-21 | 1 | -2/+0 |
* | bsps: Convert clock drivers to use a timecounter | Alexander Krutwig | 2015-05-20 | 1 | -32/+64 |
| | | | | Update #2271. | ||||
* | bsp/mpc55xx: Fix flash settings | Sebastian Huber | 2015-03-17 | 1 | -13/+16 |
* | Add fsscandir01 variants as needed to more BSPs testsuite configuration | Joel Sherrill | 2015-03-06 | 6 | -0/+6 |
* | Temporarily ignore dl* tests on some PowerPC BSPs | Joel Sherrill | 2015-03-06 | 4 | -0/+20 |
| | | | | | | | | Some BSPs have issues linking the dl* tests. These issues have not been investigated. This is a temporary workaround until we have an explanation and permanent solution. updates 2258. | ||||
* | Always disable networking for h8300 | Joel Sherrill | 2015-03-06 | 8 | -0/+8 |
* | bsp/mpc55xxevb: Fix warnings | Sebastian Huber | 2014-12-15 | 2 | -2/+10 |
* | bsps/powerpc: Disable SPE for soft-float variants | Sebastian Huber | 2014-12-15 | 1 | -1/+1 |
* | Update bug report URL | Sebastian Huber | 2014-12-05 | 1 | -1/+1 |
* | bsp/mpc55xxevb: Fix flash settings for MPC5510 | Sebastian Huber | 2014-10-31 | 1 | -22/+43 |
* | bsp/mpc55xxevb: Fix warnings | Sebastian Huber | 2014-10-10 | 1 | -5/+5 |
* | bsps: Fix build error | Sebastian Huber | 2014-09-18 | 2 | -5/+1 |
| | | | | Fix build error introduced in f535fe5311978af53635c2da8e5cb10ef9d78802. | ||||
* | Regenerate all preinstall.am files. | Chris Johns | 2014-08-29 | 1 | -3/+3 |
| | | | | | With this patch the preinstall.am files are in a set order and not dependent on now perl implements a hash. | ||||
* | Regenerate all preinstall.am files. | Joel Sherrill | 2014-08-28 | 1 | -6/+6 |
| | | | | | Apparently, at some point automake output changed and these were not updated. | ||||
* | multiple BSPs: Remove BSP_SMALL_MEMORY | Joel Sherrill | 2014-05-06 | 1 | -2/+0 |
* | testsuite: Add a per BSP test check for tests not to build. | Chris Johns | 2014-05-05 | 8 | -0/+102 |
| | | | | | | | | Provide a file per BSP to list tests that do not build for a BSP. This change removes the BSP_SMALL_MEMORY hack from the code. That hack was a mistake. Provide configuration files for each BSP with tests that cannot build. | ||||
* | smc91111: Move driver attach prototype to header file. | Daniel Cederman | 2014-03-21 | 1 | -5/+0 |
| | | | | Also signal to compiler that the start variable in lan91cxx_recv is only used when debugging. | ||||
* | Change all references of rtems.com to rtems.org. | Chris Johns | 2014-03-21 | 35 | -35/+35 |
* | bsps/powerpc: Use System V small-data area | Sebastian Huber | 2014-02-24 | 1 | -1/+1 |
| | | | | | | The 32-bit ABIs for thread-local storage (TLS) and EABI read-only small-data area have a conflicting register (r2) usage. Use the System V small-data instead (here r2 is system reserved). | ||||
* | score: Add RTEMS_FATAL_SOURCE_BSP | Sebastian Huber | 2014-02-19 | 7 | -50/+24 |
| | | | | | | Merge RTEMS_FATAL_SOURCE_BSP_GENERIC and RTEMS_FATAL_SOURCE_BSP_SPECIFIC into new fatal source RTEMS_FATAL_SOURCE_BSP. This makes it easier to figure out the code position given a fatal source and code. | ||||
* | powerpc: Change interrupt disable implemetation | Sebastian Huber | 2014-02-19 | 1 | -1/+0 |
| | | | | | | | | | | | | Instead of SPRG0 (= special purpose register 272) use the new global symbol _PPC_INTERRUPT_DISABLE_MASK to store the interrupt disable mask. The benefit is that it is now possible to disable interrupts without further run-time initialization in boot_card(). At least on Freescale e500 cores this leads also to a faster execution since the mfmsr and mfspr instruction require four cycles to complete. The instructions to load the mask value can execute while the mfmsr is in progress. | ||||
* | score: Add CPU counter support | Sebastian Huber | 2014-02-14 | 1 | -0/+2 |
| | | | | | | | | | Add a CPU counter interface to allow access to a free-running counter. It is useful to measure short time intervals. This can be used for example to enable profiling of critical low-level functions. Add two busy wait functions rtems_counter_delay_ticks() and rtems_counter_delay_nanoseconds() implemented via the CPU counter. | ||||
* | powerpc/mpc55xxevb: Move bspworkarea.c to bspgetworkarea.c | Chirayu Desai | 2013-11-24 | 2 | -1/+1 |
| | | | | Fixes commit 571216aceef5d59bec8022f119a0cecf97544f6f | ||||
* | mpc55xxevb: Move start.S to mpc55xxevb/start/start.S | Daniel Ramirez | 2013-11-23 | 2 | -1/+1 |
* | powerpc/mpc55xxevb: Move bspworkareainit.c to bspgetworkarea.c | Chirayu Desai | 2013-11-23 | 2 | -1/+1 |
| | | | | * Move bsp_work_area_initialize() | ||||
* | powerpc/mpc55xxevb: Move startup/reset.c to startup/bspreset.c | Chirayu Desai | 2013-11-23 | 2 | -1/+1 |
* | bsp/mpc55xx: Add MPC5668G support | Sebastian Huber | 2013-07-15 | 10 | -7/+66 |
* | bsp/mpc55xx: Update due to API changes | Sebastian Huber | 2013-07-05 | 2 | -16/+12 |
| | | | | | Termios notifies now the driver about an inactive transmit with the length argument set to zero. | ||||
* | bsp/mpc55xx: Avoid integer overflow | Sebastian Huber | 2013-07-05 | 1 | -2/+2 |
* | bsp/mpc55xx: Round PLL divider up | Sebastian Huber | 2013-07-05 | 1 | -1/+2 |
* | bsps/powerpc: Delete bsp_exceptions_in_RAM | Sebastian Huber | 2013-06-21 | 1 | -4/+4 |
| | | | | | Delete ppc_exc_vector_base. Add and use ppc_exc_initialize_with_vector_base(). | ||||
* | bsp/mpc55xx: eDMA API changes | Sebastian Huber | 2013-04-08 | 1 | -18/+14 |
* | bsp/mpc55xx: Add PCR index enumeration | Sebastian Huber | 2013-04-08 | 1 | -0/+1 |
* | bsp/mpc55xx: New define MPC55XX_PERIPHERAL_CLOCK | Sebastian Huber | 2013-04-08 | 1 | -0/+3 |
* | bsp/mpc55xx: Rename BSP option | Sebastian Huber | 2013-04-08 | 2 | -6/+6 |
* | bsp/mpc55xx: New fatal errors | Sebastian Huber | 2013-04-08 | 1 | -1/+3 |
* | bsp/mpc55xx: Include <bsp/linker-symbols.h> | Sebastian Huber | 2013-04-08 | 1 | -0/+1 |
* | bsp/mpc55xx: Fix warnings | Sebastian Huber | 2013-04-08 | 2 | -8/+7 |
* | RTEMS: Delete ChangeLog files. | Gedare Bloom | 2013-03-08 | 1 | -396/+0 |
| | | | | | | | | | This commit deletes all RTEMS ChangeLog files. These files have been abandoned since converting to git version control. The historical data may be recovered by checking out any commit before this one. Most of the contents of these ChangeLog files can also be found in the git log. Two external ChangeLog files, ChangeLog.slac and ChangeLog.zlib, remain. | ||||
* | bsp/mpc55xx: Fix prototype | Sebastian Huber | 2013-02-20 | 2 | -2/+2 |
* | bsp/mpc55xx: Add MPC55XX_ENABLE_START_PROLOGUE | Sebastian Huber | 2013-02-06 | 5 | -0/+51 |
* | bsp/mpc55xx: Merge RSM6 variants into one | Sebastian Huber | 2013-02-06 | 16 | -150/+85 |
* | bsp/mpc55xx: Add and use BSP specific fatal codes | Sebastian Huber | 2013-02-06 | 7 | -20/+45 |
* | bsp/mpc55xx: Add BSP_DATA_CACHE_USE_WRITE_THROUGH | Sebastian Huber | 2013-01-28 | 2 | -1/+10 |
* | bsp/mpc55xx: Fix MMU configuration for RSM6 | Sebastian Huber | 2013-01-28 | 1 | -4/+4 |
* | bsps/powerpc: Add probe handler to I2C driver | Sebastian Huber | 2013-01-09 | 1 | -2/+7 |
* | bsps/powerpc: Use explicit compiler options | Sebastian Huber | 2012-12-07 | 10 | -38/+12 |
* | bsp/mpc55xx: New BSP variants for RSM6 | Sebastian Huber | 2012-12-03 | 18 | -6/+250 |
