* | bsp/mpc55xx: Add and use MPC55XX_CHIP_FAMILY | Sebastian Huber | 2012-10-02 | 1 | -4/+4 |
* | bsp/mpc55xxevb: Change early MMU settings | Sebastian Huber | 2012-04-24 | 1 | -4/+15 |
| | | | | | | Add internal SRAM sections with cache enabled to early MMU settings. The internal SRAM initialization will use the early MMU settings. This allows applications to use cache inhibited areas in the internal SRAM. | ||||
* | Support for MPC5643L. | Sebastian Huber | 2012-01-23 | 1 | -0/+42 |
Rework of the start sequence to reduce the amount assembler code and to support configuration tables which may be provided by the application. |
