path: root/c/src/lib/libbsp/powerpc/mpc55xxevb/startup/exc-vector-base.S (follow)
* 2011-08-31 Sebastian Huber <sebastian.huber@embedded-brains.de>Sebastian Huber2011-08-311-0/+126
* startup/bspgetworkarea.c, startup/linkcmds.base: Removed files. * include/mpc55xx-config.h, make/custom/mpc5674fevb.cfg, startup/early-init.c, startup/ebi-cal-cs-config.c, startup/ebi-cs-config.c, startup/exc-vector-base.S, startup/fmpll-syncr-vals.c, startup/linkcmds.mpc5674fevb, startup/mmu-config.c, startup/siu-pcr-config.c: New files. * Makefile.am, preinstall.am: Reflect changes above. * startup/linkcmds.gwlcfm, startup/linkcmds.mpc5566evb, startup/linkcmds.phycore_mpc5554: Use linker command base file. * configure.ac: Support MPC5674F. Changed eSCI options. * clock/clock-config.c: Support MPC5674F. * i2c/i2c_init.c, network/smsc9218i.c, startup/sd-card-init.c: Update due to API changes. * include/bsp.h: Define BSP_INTERRUPT_STACK_AT_WORK_AREA_BEGIN. * network/if_smc.c: Use HAS_SMC91111. * startup/start.S, startup/bspstart.c: Moved low-level initialization into new files. Overall cleanup.
