path: root/c/src/lib/libbsp/powerpc/mpc55xxevb/network/if_smc.c (follow)
* bsps: PR2076: SMC91111 fixes for mpc55xxevb BSPPeter Dufault2012-10-021-6/+5
| | | | | | | | - A typo prevents if_smc.c from being built when configured; - The argument passed to the interrupt handler was incorrect and the addition of support for RTEMS_INTERRUPT_SHARED exposed it; - A "#ifdef DEBUG" is supposed to be "#if DEBUG" since 0 is supposed to make it quiet.
* Remove All CVS Id Strings Possible Using a ScriptJoel Sherrill2012-05-111-4/+0
* 2011-08-31 Sebastian Huber <sebastian.huber@embedded-brains.de>Sebastian Huber2011-08-311-2/+6
| | | | | | | | | | | | | | | | | | | | * startup/bspgetworkarea.c, startup/linkcmds.base: Removed files. * include/mpc55xx-config.h, make/custom/mpc5674fevb.cfg, startup/early-init.c, startup/ebi-cal-cs-config.c, startup/ebi-cs-config.c, startup/exc-vector-base.S, startup/fmpll-syncr-vals.c, startup/linkcmds.mpc5674fevb, startup/mmu-config.c, startup/siu-pcr-config.c: New files. * Makefile.am, preinstall.am: Reflect changes above. * startup/linkcmds.gwlcfm, startup/linkcmds.mpc5566evb, startup/linkcmds.phycore_mpc5554: Use linker command base file. * configure.ac: Support MPC5674F. Changed eSCI options. * clock/clock-config.c: Support MPC5674F. * i2c/i2c_init.c, network/smsc9218i.c, startup/sd-card-init.c: Update due to API changes. * include/bsp.h: Define BSP_INTERRUPT_STACK_AT_WORK_AREA_BEGIN. * network/if_smc.c: Use HAS_SMC91111. * startup/start.S, startup/bspstart.c: Moved low-level initialization into new files. Overall cleanup.
* 2011-08-30 Peter Dufault <dufault@hda.com>Sebastian Huber2011-08-301-0/+167
* make/custom/phycore_mpc5554.cfg, startup/linkcmds.phycore_mpc5554, network/if_smc.c: New files. * Makefile.am, preinstall.am: Reflect changes above. * configure.ac: Add support for the Phytec PhyCORE MPC5554. Includes: - HAS_SMC91111 to indicate a BSP has that neworking. - SMC91111_ENADDR_IS_SETUP so that it skips code to set up the MAC address. - MPC55XX_CLOCK_EMIOS_CHANNEL to permit one to set which eMIOS channel to use for the clock. - MPC55XX_BOOTFLAGS: Skips two words above the RCHW in the startup for use in skpping over the MMU setup. Required for debugging via a cheap emulator where code is loaded into RAM and then mapped in as flash. - BOARD_PHYCORE_MPC5554 If defined, use custom settings for the Phytec PhyCORE MPC5554 SOM. * clock/clock-config.c: Modify so that the EMIOS channel used for the clock can be selected at configuration time. For MPC5544 only: - Conditionally skip access to a register that faults if accessed on the MPC5554 - Do not set the control register mode as was done for GW_LCFM support, it breaks interrupts. * make/custom/mpc55xx.inc: Make it possible to override the soft-float to set the type of floating point BSP will use. * startup/start.S: Add support for the "boot flags", two long-words that I manipulate with the debugger to skip over MMU setup. Use an external for the start of external SRAM instead of the hardwired number 0x20000000. Disable write access to the internal flash.
