* startup/bspgetworkarea.c, startup/linkcmds.base: Removed files.
* include/mpc55xx-config.h, make/custom/mpc5674fevb.cfg,
startup/early-init.c, startup/ebi-cal-cs-config.c,
startup/ebi-cs-config.c, startup/exc-vector-base.S,
startup/fmpll-syncr-vals.c, startup/linkcmds.mpc5674fevb,
startup/mmu-config.c, startup/siu-pcr-config.c: New files.
* Makefile.am, preinstall.am: Reflect changes above.
* startup/linkcmds.gwlcfm, startup/linkcmds.mpc5566evb,
startup/linkcmds.phycore_mpc5554: Use linker command base file.
* configure.ac: Support MPC5674F. Changed eSCI options.
* clock/clock-config.c: Support MPC5674F.
* i2c/i2c_init.c, network/smsc9218i.c, startup/sd-card-init.c: Update
due to API changes.
* include/bsp.h: Define BSP_INTERRUPT_STACK_AT_WORK_AREA_BEGIN.
* network/if_smc.c: Use HAS_SMC91111.
* startup/start.S, startup/bspstart.c: Moved low-level initialization
into new files. Overall cleanup.
