2018-04-20 | bsps: Move console drivers to bsps | Sebastian Huber | 1 | -354/+0 | |
This patch is a part of the BSP source reorganization. Update #3285. | |||||
2017-04-03 | bsps: Fix baud settings | Sebastian Huber | 1 | -1/+1 | |
Update #2897. | |||||
2014-03-21 | Change all references of rtems.com to rtems.org. | Chris Johns | 1 | -1/+1 | |
2014-02-19 | score: Add RTEMS_FATAL_SOURCE_BSP | Sebastian Huber | 1 | -3/+4 | |
Merge RTEMS_FATAL_SOURCE_BSP_GENERIC and RTEMS_FATAL_SOURCE_BSP_SPECIFIC into new fatal source RTEMS_FATAL_SOURCE_BSP. This makes it easier to figure out the code position given a fatal source and code. | |||||
2013-07-05 | bsp/mpc55xx: Update due to API changes | Sebastian Huber | 1 | -6/+5 | |
Termios notifies now the driver about an inactive transmit with the length argument set to zero. | |||||
2013-02-06 | bsp/mpc55xx: Add and use BSP specific fatal codes | Sebastian Huber | 1 | -3/+3 | |
2012-10-02 | bsp/mpc55xx: PR2077: Add BSP_DEFAULT_BAUD_RATE | Peter Dufault | 1 | -1/+1 | |
2012-07-18 | bsp/mpc55xx: Add ESCI_C and ESCI_D support | Sebastian Huber | 1 | -4/+19 | |
2012-01-23 | Support for MPC5643L. | Sebastian Huber | 1 | -0/+339 | |
Rework of the start sequence to reduce the amount assembler code and to support configuration tables which may be provided by the application. |
