These modifications were required by hand after running the script.
In some cases, the file names did not match patterns. In others,
the format of the file did not match any common patterns.
for details.
PR 1922
* preinstall.am: EDF and CBS scheduler: extern declarations fix.
* Makefile.am: Do not include ne2000.rel unless networking is enabled.
* configure.ac: changed tests so that variants
of qemuprep (e.g., qemuprep-altivec) are recognized.
* README.qemu: added.
* motorola_powerpc/make/custom/qemuprep-altivec.cfg,
motorola_powerpc/Makefile.am: added altivec-enabled variant.
* motorola_powerpc/Makefile.am,
motorola_powerpc/configure.ac, motorola_powerpc/preinstall.am,
motorola_powerpc/include/bsp.h, motorola_powerpc/make/custom/qemuprep.cfg,
motorola_powerpc/qemu_fakerom/Makefile.am,
motorola_powerpc/qemu_fakerom/.cvsignore:
Added 'qemuprep' BSP variant.
* Makefile.am: Remove references to non-existing files.
* Makefile.am: Remove reference to wrapup directory.
* configure.ac: Use standard cache BSP options.
PR1797/bsps: Applied cleaned-up version of Kate's patch.
CONFIGURE_MALLOC_BSP_SUPPORTS_SBRK is now a 'bspopts.h'
setting and as such configurable.
* include/tm27.h:
* beatnik/include/bsp.h, beatnik/irq/irq.h, beatnik/pci/gt_pci_init.c,
ep1a/console/polled_io.c, ep1a/irq/openpic_xxx_irq.c,
gen5200/include/irq.h, gen5200/irq/irq.c, gen5200/startup/bspstart.c,
haleakala/irq/irq.c, mbx8xx/irq/irq.c, mbx8xx/irq/irq.h,
motorola_powerpc/include/bsp.h, mpc8260ads/irq/irq.c,
mpc8260ads/irq/irq.h, mvme3100/include/bsp.h, mvme3100/irq/irq.h,
mvme3100/start/start.S, mvme5500/include/bsp.h, mvme5500/irq/irq.h,
psim/include/bsp.h, psim/include/coverhd.h, psim/irq/irq.h,
psim/shmsupp/addrconv.c, psim/shmsupp/getcfg.c,
psim/startup/linkcmds, psim/tools/psim-gdb-top.in,
psim/tools/psim-top.in, psim/tools/runtest-top.in, qemuppc/irq/irq.h,
score603e/irq/irq.c, shared/bootloader/bootldr.h,
shared/bootloader/em86.c, shared/bootloader/em86real.S,
shared/bootloader/exception.S, shared/bootloader/head.S,
shared/bootloader/lib.c, shared/bootloader/misc.c,
shared/bootloader/mm.c, shared/bootloader/pci.c,
shared/console/console.c, shared/console/consoleIo.h,
shared/console/inch.c, shared/console/keyboard.h,
shared/console/polled_io.c, shared/irq/i8259.c, shared/irq/irq.h,
shared/irq/openpic_i8259_irq.c, shared/motorola/motorola.c,
shared/motorola/motorola.h, shared/openpic/openpic.c,
shared/openpic/openpic.h, shared/pci/pci.c,
shared/residual/residual.c, shared/start/start.S, ss555/irq/irq.h:
Fix typo where license said found in found in.
* configure.ac: Remove AC_CHECK_SIZEOF([void *]).
* configure.ac: Added AC_CHECK_SIZEOF macro.
* make/custom/mcp750.cfg: Remove RTEMS_BSP_FAMILY.
* make/custom/mtx603e.cfg: Remove RTEMS_BSP_FAMILY.
* make/custom/mvme2100.cfg: Remove RTEMS_BSP_FAMILY.
* make/custom/mvme2307.cfg: Remove RTEMS_BSP_FAMILY.
* make/custom/mcp750.cfg: New (relocated from /make/custom).
* make/custom/mtx603e.cfg: New (relocated from /make/custom).
* make/custom/mvme2100.cfg: New (relocated from /make/custom).
* make/custom/mvme2307.cfg: New (relocated from /make/custom).
* configure.ac: Remove RTEMS_BSP_BOOTCARD_OPTIONS.
* include/bsp.h: Eliminate BSPs defining NUMBER_OF_TERMIOS_PORTS.
Should be automatically handled by confdefs.h or the application.
* configure.ac: Rename BSP_BOOTCARD_OPTIONS to
RTEMS_BSP_BOOTCARD_OPTIONS. Add RTEMS_BSP_CLEANUP_OPTIONS so all BSPs
have the same options.
* bsp_specs: Remove -Qy from *link.
* bsp_specs: Move -e start from *link to *startfile to avoid warning
for undefined entry symbol when linking relocatables with binutils
2.19.
* Makefile.am: Eliminate bsp.am. Build startup files as side-effect
of building libbspstart.a, using automake-rules.
* Makefile.am: Eliminate *_SOURCES.
* Makefile.am: Move noinst_LIBRARIES = libbsp.a before its
components.
* Makefile.am: Cleanup ../../shared/include/bootcard.h handling.
* Makefile.am, configure.ac: Make letting boot_card() handle work area
allocation mandatory. Rename
RTEMS_BSP_BOOTCARD_HANDLES_RAM_ALLOCATION to BSP_BOOTCARD_OPTIONS.
* Makefile.am, include/bsp.h: Use standardized bsp_cleanup() which can
optionally print a message, poll for user to press key, and call
bsp_reset(). Using this eliminates the various bsp_cleanup()
implementations which had their own implementation and variety of
string constants.
* include/bsp.h: Add use of bsp_get_work_area() in its own file and
rely on BSP Framework to perform more initialization.
* Makefile.am: Rework to avoid .rel files.
* Makefile.am: use new irq_bspsupport.rel which was
split out of exc_bspsupport.rel to provide finer-grained
control over what BSPs want to use.
* include/bsp.h: Eliminate copies of the Configuration Table. Use the
RTEMS provided accessor macros to obtain configuration fields.
* Makefile.am: use shared exception/interrupt support
from libcpu/powerpc/new-exceptions/bspsupport rather
than ../shared/vectors , ../shared/irq
2007-12-10 Till Straumann <strauman@slac.stanford.edu>
* shared/vectors/vectors_entry.S, motorola_powerpc/bsp_specs,
shared/start/vectors_entry.S: moved vectors_entry.S to
'start' subdir and made a start file rather than
element of vectors.rel (it should always be linked but
won't if it is the sole member of vectors.rel).
* Makefile.am: merged shared/vme/vme_universe.c and
shared/vme/vme_universe_dma.c into one file.
