Fix build error introduced in f535fe5311978af53635c2da8e5cb10ef9d78802.
not updated.
PR 1922
* preinstall.am: EDF and CBS scheduler: extern declarations fix.
* motorola_powerpc/Makefile.am,
motorola_powerpc/configure.ac, motorola_powerpc/preinstall.am,
motorola_powerpc/include/bsp.h, motorola_powerpc/make/custom/qemuprep.cfg,
motorola_powerpc/qemu_fakerom/Makefile.am,
motorola_powerpc/qemu_fakerom/.cvsignore:
Added 'qemuprep' BSP variant.
* Makefile.am: Cleanup ../../shared/include/bootcard.h handling.
* Makefile.am: use shared exception/interrupt support
from libcpu/powerpc/new-exceptions/bspsupport rather
than ../shared/vectors , ../shared/irq
2007-12-10 Till Straumann <strauman@slac.stanford.edu>
* shared/vectors/vectors_entry.S, motorola_powerpc/bsp_specs,
shared/start/vectors_entry.S: moved vectors_entry.S to
'start' subdir and made a start file rather than
element of vectors.rel (it should always be linked but
won't if it is the sole member of vectors.rel).
* Makefile.am: irq_supp.h was moved from shared/irq to
libcpu/powerpc/new-exceptions/bspsupport.
* preinstall.am: Moved most of the remaining CPU Table fields to the
Configuration Table. This included pretasking_hook, predriver_hook,
postdriver_hook, idle_task, do_zero_of_workspace,
extra_mpci_receive_server_stack, stack_allocate_hook, and
stack_free_hook. As a side-effect of this effort some multiprocessing
code was made conditional and some style clean up occurred.
* Makefile.am, preinstall.am, include/bsp.h:
Use VME DMA support implemented by vmeUniverse and
libbsp/powerpc/shared/vme/vme_universe_dma.c
Added explanation for use of BSP_PIC_DO_EOI by
BSP implementors who derive from this 'include/bsp.h'.
* ep1a/Makefile.am, ep1a/preinstall.am,
* motorola_powerpc/Makefile.am, motorola_powerpc/preinstall.am,
* score603e/Makefile.am, score603e/preinstall.am,
* shared/vme/VME.h:
moved VME.h from libbsp/powerpc/shared/vme to
libbsp/shared/vmeUniverse; eventually, this (and other)
VME API headers should migrate to cpukit.
