* bootloader/Makefile.am: Cosmetics.
* irq/Makefile.am: Add preinstallation dirstamp support.
* motorola/Makefile.am: Cosmetics.
* openpic/Makefile.am: Cosmetics.
* pci/Makefile.am: Cosmetics.
* residual/Makefile.am: Cosmetics.
* start/Makefile.am: Cosmetics.
* vectors/Makefile.am: Add preinstallation dirstamp support.
* vme/Makefile.am: Add preinstallation dirstamp support.
* irq/Makefile.am: Remove all-local: $(ARCH).
* motorola/Makefile.am: Remove all-local: $(ARCH).
* openpic/Makefile.am: Remove all-local: $(ARCH).
* pci/Makefile.am: Remove all-local: $(ARCH).
* residual/Makefile.am: Remove all-local: $(ARCH).
* vme/Makefile.am: Remove all-local: $(ARCH).
bootloader/Makefile.am: Reflect having moved automake.
irq/Makefile.am: Reflect having moved automake.
motorola/Makefile.am: Reflect having moved automake.
openpic/Makefile.am: Reflect having moved automake.
pci/Makefile.am: Reflect having moved automake.
residual/Makefile.am: Reflect having moved automake.
vme/Makefile.am: Reflect having moved automake.
* bootloader/Makefile.am: Don't include @RTEMS_BSP@.cfg.
* irq/Makefile.am: Don't include @RTEMS_BSP@.cfg.
* motorola/Makefile.am: Don't include @RTEMS_BSP@.cfg.
* openpic/Makefile.am: Don't include @RTEMS_BSP@.cfg.
* pci/Makefile.am: Don't include @RTEMS_BSP@.cfg.
* residual/Makefile.am: Don't include @RTEMS_BSP@.cfg.
* vectors/Makefile.am: Don't include @RTEMS_BSP@.cfg.
* bootloader/Makefile.am: Use .$(OBJEXT) instead of .o.
* irq/Makefile.am: Use .$(OBJEXT) instead of .o.
* motorola/Makefile.am: Use .$(OBJEXT) instead of .o.
* openpic/Makefile.am: Use .$(OBJEXT) instead of .o.
* pci/Makefile.am: Use .$(OBJEXT) instead of .o.
* residual/Makefile.am: Use .$(OBJEXT) instead of .o.
* bootloader/Makefile.am: Remove AUTOMAKE_OPTIONS.
* motorola/Makefile.am: Remove AUTOMAKE_OPTIONS.
* openpic/Makefile.am: Remove AUTOMAKE_OPTIONS.
* pci/Makefile.am: Remove AUTOMAKE_OPTIONS.
* residual/Makefile.am: Remove AUTOMAKE_OPTIONS.
* vectors/Makefile.am: Remove AUTOMAKE_OPTIONS.
* bootloader/Makefile.am, clock/Makefile.am, console/Makefile.am,
irq/Makefile.am, motorola/Makefile.am, openpic/Makefile.am,
pci/Makefile.am, residual/Makefile.am, start/Makefile.am,
startup/Makefile.am, vectors/Makefile.am, wrapup/Makefile.am:
Include compile.am
converted to automake.
As part of this effort, the mpc750 libcpu code is now shared with the
ppc6xx.
ppc6xx.
independently of a BSP.
BSP needs to be eliminated.
