path: root/c/src/lib/libbsp/powerpc/motorola_powerpc/clock (follow)
* 2002-12-17 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2002-12-171-1/+0
| | | | | | | | | | | | | | * bootloader/Makefile.am: Don't include @RTEMS_BSP@.cfg. * clock/Makefile.am: Don't include @RTEMS_BSP@.cfg. * console/Makefile.am: Don't include @RTEMS_BSP@.cfg. * irq/Makefile.am: Don't include @RTEMS_BSP@.cfg. * motorola/Makefile.am: Don't include @RTEMS_BSP@.cfg. * openpic/Makefile.am: Don't include @RTEMS_BSP@.cfg. * pci/Makefile.am: Don't include @RTEMS_BSP@.cfg. * residual/Makefile.am: Don't include @RTEMS_BSP@.cfg. * start/Makefile.am: Don't include @RTEMS_BSP@.cfg. * startup/Makefile.am: Don't include @RTEMS_BSP@.cfg. * vectors/Makefile.am: Don't include @RTEMS_BSP@.cfg.
* 2002-08-11 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2002-08-111-1/+1
| | | | | | | | | | | | | | | * bootloader/Makefile.am: Use .$(OBJEXT) instead of .o. * clock/Makefile.am: Use .$(OBJEXT) instead of .o. * console/Makefile.am: Use .$(OBJEXT) instead of .o. * irq/Makefile.am: Use .$(OBJEXT) instead of .o. * motorola/Makefile.am: Use .$(OBJEXT) instead of .o. * openpic/Makefile.am: Use .$(OBJEXT) instead of .o. * pci/Makefile.am: Use .$(OBJEXT) instead of .o. * residual/Makefile.am: Use .$(OBJEXT) instead of .o. * start/Makefile.am: Use .$(OBJEXT) instead of .o. * startup/Makefile.am: Use .$(OBJEXT) instead of .o. * vectors/Makefile.am: Use .$(OBJEXT) instead of .o. * wrapup/Makefile.am: Use .$(OBJEXT) instead of .o.
| | | | | | | | | | | | | | | | | | | | * configure.ac: AC_INIT(package,_RTEMS_VERSION,_RTEMS_BUGS). AM_INIT_AUTOMAKE([no-define foreign 1.6]). * bootloader/Makefile.am: Remove AUTOMAKE_OPTIONS. * Makefile.am: Remove AUTOMAKE_OPTIONS. * clock/Makefile.am: Remove AUTOMAKE_OPTIONS. * console/Makefile.am: Remove AUTOMAKE_OPTIONS. * include/Makefile.am: Remove AUTOMAKE_OPTIONS. * irq/Makefile.am: Remove AUTOMAKE_OPTIONS. * motorola/Makefile.am: Remove AUTOMAKE_OPTIONS. * openpic/Makefile.am: Remove AUTOMAKE_OPTIONS. * pci/Makefile.am: Remove AUTOMAKE_OPTIONS. * residual/Makefile.am: Remove AUTOMAKE_OPTIONS. * start/Makefile.am: Remove AUTOMAKE_OPTIONS. * startup/Makefile.am: Remove AUTOMAKE_OPTIONS. * vectors/Makefile.am: Remove AUTOMAKE_OPTIONS. * wrapup/Makefile.am: Remove AUTOMAKE_OPTIONS.
* 2000-09-04 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2000-09-051-0/+1
| | | | | | | | * bootloader/Makefile.am, clock/Makefile.am, console/Makefile.am, irq/Makefile.am, motorola/Makefile.am, openpic/Makefile.am, pci/Makefile.am, residual/Makefile.am, start/Makefile.am, startup/Makefile.am, vectors/Makefile.am, wrapup/Makefile.am: Include compile.am
* Merged from 4.5.0-beta3aJoel Sherrill2000-06-121-2/+2
* Patch rtems-rc-4.5.0-13-cvs.diff from Ralf Corsepius <corsepiu@faw.uni-ulm.de>.Joel Sherrill2000-04-131-0/+2
| | | | adds .cvsignore.
* Patches rtems-rc-20000118-3.diff and rtems-rc-20000118-4.diff fromJoel Sherrill2000-01-312-66/+25
| | | | | | | | | | Ralf Corsepius <corsepiu@faw.uni-ulm.de> that contain: * Modifications, (minor) corrections, cleanups to most existing Makefile.ams * Adds automake support to all remaining BSPs which have not yet been converted to automake. * Makefile.am for all remaining wrapup/Makefile.ams
* Patch rtems-rc-20000104-12.diff from Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2000-01-101-2/+2
| | | | | | | | which converts the PowerPC BSPs to configuration and more automake. * Besides adding partial automake support, rsp converting all powerpc BSPs to make them compliant to the new configuration scheme, this patch attempts to fix several configuration bugs in powerpc related Makefiles.
* Merged of mcp750 and mvme2307 BSP by Eric Valette <valette@crf.canon.fr>.Joel Sherrill1999-12-021-7/+2
| | | | | As part of this effort, the mpc750 libcpu code is now shared with the ppc6xx.
* Merged of mcp750 and mvme2307 BSP by Eric Valette <valette@crf.canon.fr>.Joel Sherrill1999-12-021-37/+0
* Patch rtems-rc-19991117-9.diff from Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill1999-11-221-1/+1
| | | | | to convert the libc directory to automake and "dozens of small fixes for Makefile.ins/configure.ins below c/src/lib."
* Patch from Eric Valette <valette@crf.canon.fr> so this will buildJoel Sherrill1999-11-053-222/+40
| | | | independently of a BSP.
* The files in libcpu should not be directly dependent on any BSP. InJoel Sherrill1999-11-042-0/+290
particular, using bsp.h, or getting information from the BSP which should properly be obtained from RTEMS is forbidden. This is necessary to strengthen the division between the BSP independent parts of RTEMS and the BSPs themselves. This started after comments and analysis by Ralf Corsepius <corsepiu@faw.uni-ulm.de>. The changes primarily eliminated the need to include bsp.h and peeking at BSP_Configuration. The use of Cpu_table in each BSP needs to be eliminated.
