Close #3250.
Close #4081.
Update #4267.
controller support.
Update #3269.
Update #3285.
Update #3285.
Update #3285.
This bootloader is only used by the motorola_powerpc BSP.
Update #3285.
Update #3285.
Update #3285.
Update #3285.
Update #3285.
Update #3285.
Update #3285.
Update #3285.
Update #3285.
Update #3285.
Update #3285.
Update #2408.
This shared powerpc file was only used by this BSP.
Update #3285.
Update #3285.
Update #3285.
Update #3285.
Update #3285.
Update #3285.
This was used by the not supported "make dist".
Update #3285.
Update #3285.
This file was used by this BSP only. Avoid RTEMS_RELLDFLAGS.
Update #3285.
Update #3285.
The VME support is only used by powerpc BSPs.
Update #3285.
Update #3285.
Update #3285.
Update #3285.
Update #3285.
Update #3285.
Update #3285.
Update #3285.
Use only one timer driver variant based on the standard PowerPC time
base.
Update #3285.
Update #3285.
Update #3285.
Update #3285.
* bsps/shared/cache
Update #3285.
line option.
may suppress warnings.
erc32, imx, qoriq, etc.
* cpukit/include
* cpukit/libnetworking
* bsps/include
* bsps/@RTEMS_CPU@/include
order.
Update #3254.
This header is used also by the motorola_powerpc BSP.
Update #3254.
Update #3254.
Update #3254.
