* configure.ac: Remove RTEMS_ENABLE_NETWORKING.
* Makefile.am: Add @exceptions@ to SUBDIRS;
Remove need_motorola_powerpc.
* configure.ac: Apply RTEMS_BSPOPTS_*(*) to merge-in settings from
make/custom/mcp750.cfg, make/custom/mvme2307.cfg;
Remove need_motorola_powerpc;
Add RTEMS_PPC_EXCEPTIONS([new]).
* include/Makefile.am: Replace PREINSTALL_FILES with
TMPINSTALL_FILES, include force-preinstall.am.
* wrapup/Makefile.am: Apply @exceptions@.
* configure.ac: Add bspopts.h.
* include/.cvsignore: Add stamp-h* and bspopts.h*.
* include/Makefile.am: Add bspopts.h.
* pci/Makefile.am: Append -O2 to AM_CFLAGS.
* bootloader/Makefile.am: completely reworked.
* configure.ac: Add AM_PROG_AS.
* startup/linkcmds: Added _init and _fini.
* configure.in: Remove.
* residual/Makefile.am: Use 'PREINSTALL_FILES ='.
* vectors/Makefile.am: Use 'PREINSTALL_FILES ='.
* pci/Makefile.am: Use 'PREINSTALL_FILES ='.
* openpic/Makefile.am: Use 'PREINSTALL_FILES ='.
* bootloader/Makefile.am: Use 'CLEANFILES ='.
* bootloader/Makefile.am: Modified to install bootloader so
make-exe rule can avoid writing to install point or assuming
BSP build tree is available.
* startup/linkcmds: Added lines so DWARF debug information
would be available. Otherwise gdb complains that the offsets
for the debug info are incorrect and doesn't load the files.
* bootloader/Makefile.am, clock/Makefile.am, console/Makefile.am,
irq/Makefile.am, motorola/Makefile.am, openpic/Makefile.am,
pci/Makefile.am, residual/Makefile.am, start/Makefile.am,
startup/Makefile.am, vectors/Makefile.am, wrapup/Makefile.am:
Include compile.am
