path: root/c/src/lib/libbsp/powerpc/mcp750/dec21140 (follow)
* tch from Eric Valette <valette@crf.canon.fr> and Emmanuel RaguetJoel Sherrill1999-10-251-36/+36
| | | | | <raguet@crf.canon.fr> to fix bugs and make the mcp750 boot RTEMS running the GoAhead web server.
* Patch from Eric Valette <valette@crf.canon.fr> and Emmanuel RaguetJoel Sherrill1999-08-101-2/+3
| | | | | | | | | | | | <raguet@crf.canon.fr>: - the dec21140 driver code has been hardened (various bug fixed) Emmanuel, - bug in the mcp750 init code have been fixed (interrupt stack/initial stack initialization), BSS correctly cleared (Eric V) - remote debugging over TCP/IP is nearly complete (berakpoints, backtrace, variables,...) (Eric V), - exception handling code has also been improved in order to fully support RDBG requirements (Eric V),
* Patch from Eric Valette <valette@crf.canon.fr>:Joel Sherrill1999-07-091-6/+3
| | | | | | | | | | | | | | | - The same bug fix that was done on pc386 to prevent interrupt from occuring (never experienced it but who knows as I have 8259 emulation :() - Removed every compiler warning (except wrong ones and ones I can't do anything). - Removed any libc available code in code linked with mcp750 rtems executbale. Unfortunately using newlib functions for linking the bootloader does not work as the compilation options in bootloader (-mrelocatable -fixed-r13) are not compatible with newlib options. => I have put any libc external reference in one single new file (lib.c) that is linked only with the boot loader. Removing the file from ${OBJ} and using -lc crash the bootloader. Added big warning...
* New files missed in previous addition.Joel Sherrill1999-07-031-0/+907
